1. Snareman's Avatar
    I've been using The Air Dock - The Charging Dock for your Smartphone for a few years now, but it seems to have stopped working in the last few months on my S7E and still doesn't work on my 8+. I have a Tylt car charger in my other car, but its kind of large and slow, often losing charge as I use Waze and streaming. Has anyone found a good wireless car charger that isn't huge and ugly?
    04-22-2017 03:05 PM
  2. Kirk Maluo's Avatar
    This one works great for me despite a 3 star rating. Just needs a qc 2.0 car charger.
    Qi-Infinity Fast Wireless Car Charger Dock; 1.5A (2A Max, 10 Watt) For Samsung S6 Edge/Note5 & Compatible with Qi-Enabled Devices https://www.amazon.com/dp/B018INZ10O...cUvbUpU5778043
    04-22-2017 06:15 PM
  3. Snareman's Avatar
    Just found this as well https://www.amazon.com/Magnetic-Wire...cUvbUpU5778637
    Magnetic Wireless Qi Cell Phone Charger, Air Vent Car Charging Mount Holder Cradle for Android and iPhone
    04-23-2017 01:28 AM
  4. Kirk Maluo's Avatar
    Looks cool if you don't need quickcharge. I think you need to attach a metal piece to your phone or case as well.
    04-23-2017 02:34 PM
  5. mikef91's Avatar
    Buy a Toyota. Most models have the option for Qi wireless charging built in. My Tacoma has it, but I never use it because it takes way too long to charge. I have a Samsung Fast Charge car charger that I've been using since the S7 came out.
    04-23-2017 03:37 PM
  6. Snareman's Avatar
    My BMW has it too, but its stupidly placed in the center arm rest console and is completely useless (and slow). I want it up at eye level so I can use Waze.
    04-23-2017 03:41 PM
  7. Snareman's Avatar
    There is usually a magnet on the charger that will pull the back of the phone to it enough. The AirDock also has some type of little microsuction material on it. I'm happy if the charge at least doesn't decrease any while I'm driving with Waze and audio streaming going. On the rare occasion where I need it to charge a bunch I can just plug it in to a fast car charger.
    04-23-2017 03:44 PM
  8. Kirk Maluo's Avatar
    Yeah, the Toyota charging location is inconvenient as your phone will be out of site. May be a good thing though.
    04-23-2017 03:44 PM
  9. Kirk Maluo's Avatar
    Unfortunately, wireless chargers often can't keep up with phone on usage. I often get weak charging detected errors. Also, Fast wireless chargers will default to standard wireless charging when the screen is on. The S8 also throws battery temperature errors which halt wireless charging until it cools down. So unfortunately no perfect solution, but still convenient not having to plug it in when you get in your car.
    04-23-2017 03:50 PM
  10. Snareman's Avatar
    I have been using my larger Tylt Vu charger for the past few days since I got the phone. Today I drove 40 minutes using both Waze with the screen on the whole-time and streaming audio and the phone stayed at 100%. I was actually kind of surprised.
    04-23-2017 03:53 PM
  11. amazingkyo's Avatar
    how long it takes fully charged your phone ?
    08-17-2017 05:03 AM
  1. Wireless Car Charger Mount advice?
    By thehoz in forum Samsung Galaxy S8 & S8+
    Last Post: 04-28-2017, 08:48 PM
  2. Wall Chargers
    By NismoZ in forum Samsung Galaxy S8 & S8+ Cases & Accessories
    Last Post: 04-28-2017, 04:28 PM
  3. Android Auto wont display on my cars touchscreen
    By AC Question in forum LG G4
    Last Post: 04-22-2017, 03:02 PM
  4. Any issues with GPS?
    By flick0416 in forum LG G6
    Last Post: 04-22-2017, 12:53 PM
  5. Best way to unlock the S8+ while in a car mount?
    By felloffthetruck in forum Samsung Galaxy S8 & S8+
    Last Post: 04-22-2017, 11:37 AM
