1. PhoneQuestion's Avatar
    Casting:
    I came from an LG G4, using the default music app, I was able to cast audio to my Google Chromecast audio using the miracast from the quick menu.
    I can't find a similar feature with the S8, I was reading I can use a "quick connect" from the drop down menu but I don't see this as an option. I am using Google Play Music since Samsung didn't have a built in music app. (I already tried to cast within the app but it will not do so unless I upload the music to Google.)
    Folders:
    Also, is it possible to resize folders? On the LG when I had folders on the home screen the pop-up showing the folder contents grew as I added items. With the S8, even if I only have 4 apps in the folder it takes up the whole screen and is harder to reach way at the top.
    Thanks.
    04-22-2017 03:49 PM
  1. Replies: 1
    Last Post: 04-22-2017, 05:03 PM
  2. Replies: 1
    Last Post: 04-22-2017, 02:51 PM
  3. Replies: 1
    Last Post: 04-22-2017, 02:49 PM
  4. What are the start visit and end visit popups on my screen.
    Last Post: 04-22-2017, 02:03 PM
  5. Replies: 0
    Last Post: 04-22-2017, 12:57 PM
