03-06-2018 07:19 AM
89 ... 234
tools
  1. gundam212's Avatar
    So...I think I've finally figured out how to get S8 Edge lighting to work. I've tried ever single suggestion on here to no avail. Somehow got lucky playing with settings and it works. In settings under display- tap on screen mode. At bottom there is a "Screen Edge Color Balance" just adjust one notch in whatever direction doesn't really make much difference. Will get message "may take up to 10 minutes and phone may restart twice". Mine took about 20 seconds and restarted and now it WORKS! no need for a 3rd party app. Hope this helps end some of the frustration I'm reading.
    Works like a charm!
    05-25-2017 07:00 AM
  2. Smply_Rckless's Avatar
    Tried this, didn't work for all apps. I'm only getting it for Textra, CNN, Facebook & Twitter. It did fix this little red tint issue I was having at the bottom of my nav bar. Thanks for that. 😁
    05-25-2017 08:02 AM
  3. alexcapone's Avatar
    FYI the edge lighting app on play store is getting bad reviews from S8+ users
    05-25-2017 09:18 AM
  4. T22rmh's Avatar
    Works for me. it only works when the screen is not locked as it's supposed too.
    05-25-2017 10:32 AM
  5. Kalvin Kerns's Avatar
    Edge Lighting is the name of an app that adds huge functionality to the built in edge lighting on the S8 and YES Edge Lighting (THE APP) does work.
    Shouldn't need a third party app for edge lighting. Samsung built and owns this. It should just work out of the box.
    Ramsz likes this.
    05-25-2017 10:49 AM
  6. kvisintine's Avatar
    Does it work for other apps? This feature is so buggy. It never works when the screen is off like it is supposed to. The only apps that work for me are pushbullet and Android messages when the screen is on.
    07-08-2017 05:19 PM
  7. kvisintine's Avatar
    Have you had any luck since you posted this? I got an update on my Sprint GS8+ today that updated the nav bar but Edge lighting still does not work. I've spent so much time trying to get this to work but still nothing. PUshbullet and Android Messages work when the screen is off.
    07-08-2017 05:24 PM
  8. joe_fresh's Avatar
    I have only seen mine work while screen is on. I have yet to get it to work with AOD off and screen off.
    07-09-2017 09:22 AM
  9. Moe Savoie's Avatar
    It worked fine on my Note 8. But, I decided to change from the stock messaging app to Android Messages. Ever since then, it stopped working.
    10-21-2017 05:18 AM
  10. dwayne3686's Avatar
    We installed Edge Lighting from the app store to get different colors for different apps. That feature in not available on the stock Edge Lighting.
    I don't see how to get different color lights for different apps.
    10-28-2017 02:18 PM
  11. markst's Avatar
    No luck here. On T-Mobile
    10-30-2017 12:26 PM
  12. s8plusboy's Avatar
    I have found that the edge lighting only works when your phone is face down. My s8+ edge lighting works flawlessly face down, nothing when not.was told that is the only time us should light up so I guess it is kind of a pointless operation. Hope this helps!
    02-02-2018 12:11 PM
  13. Lawrie Sherratt's Avatar
    Make sure it's enabled for all apps. By default mine was only set for messaging app. Once I enabled for all apps it works as it should.
    Thanks for that tip my friend. That has worked.
    02-03-2018 12:18 PM
  14. Ivan Vojtko's Avatar
    Hello. I've got solution for edge notifications. Using this app, you can enable edge notification for any app installed and even select color of edge notification. It uses native samsung notifications, so it works even with AOD.
    https://play.google.com/store/apps/d...t.edgelighting
    I really worth the money. Here is video showing gmail notification.
    03-06-2018 07:19 AM
89 ... 234
  1. S8+ Rebooting often on Day 3 (today)
    By Dualmonitors in forum Samsung Galaxy S8 & S8+
    Last Post: 04-25-2017, 08:16 AM
  2. Adoptive storage in Galaxy S8??
    By Oscar Maradiaga in forum Samsung Galaxy S8 & S8+
    Last Post: 04-22-2017, 10:35 PM
  3. G6 vs S8 vs Pixel camera shootout
    By bhatech in forum LG G6
    Last Post: 04-22-2017, 06:10 PM
  4. How to get here wego on gear s3
    Last Post: 04-22-2017, 03:56 PM
  5. Contact info on AOD?
    By tabs31 in forum Samsung Galaxy S8 & S8+
    Last Post: 04-22-2017, 03:28 PM
