The screen on the S8+ doesn't seem to get as greasy and dirty as the S7 Edge...
Misterb
742
Gorilla Glass 5. It's new but I'm not sure if the oleophobic coating is new.
Awesome. Sounds promising. I looked up 5, and all I can see is stuff about it being more durable. Since it is more durable, maybe the surface is somehow less susceptible to grease
Snareman
2,356
33
48
I agree that my finger seems to slide easier. I also think I remember that it took awhile before the screen started getting gunky. I have no idea why, but it seemed to be a little more susceptible to gunk later in its life for some odd reason. So far so good for the 8.
