11-18-2017 12:55 AM
59 123
tools
  1. JmfinD's Avatar
    I'm on Sprint and have the exact same issue. I took it to a Sprint store and suggested I get a replacement because I was within my 15 days. I'm still having the same issue with the replacement
    Dandre Norman likes this.
    07-01-2017 09:39 AM
  2. JmfinD's Avatar
    I'm in Atlanta with the same issue of slow speed. Phone died LTE but speeds are super slow
    07-01-2017 09:40 AM
  3. DarkSorrow's Avatar
    Works good for me. 85 mbps down. AT&T carrier.
    http://www.speedtest.net/my-result/a/2977030336
    07-06-2017 03:20 PM
  4. mgbosshogg's Avatar
    More than happy with S8 4G speeds, more than required on a phone.
    07-06-2017 04:03 PM
  5. PatG9234's Avatar
    I'm having the same issue with my S8 on Sprint. Sprint CS has been no help. They've had me replace my SIM card (which ended up breaking my calling, since fixed), update network settings (some pound code), and re-provision.
    I've read online about prioritizing bands, but I'll need to get the MSL out of Sprint CS first. My speeds are generally <1Mbps download to 6-10Mbps. There is one cell tower I connect to on my way into work at a train station that I get 60+Mbps, but every other time it's abysmal.
    Any advice from the experts?
    09-13-2017 10:53 AM
  6. brianjsw's Avatar
    I have had slow or unusable LTE with Sprint ever since they turned on Band 41. Symptoms of the problem are that the phone believes it's got an LTE signal but data is not available. Sometimes it will download a speed test and die half way through. Other times the upload will show less than 0.25Mbps speed. Problem spanned three different cell phones exact same symptoms at the same location. After over a year of messing around, finally discovered the problem is Sprint tuned their phones to try to use Band 41 even when the signal is too weak. Going into the DEBUG menu, LTE Engineering, disabled band 41 as well as all the Band 41 CA settings, restarted phone, and my service has been great and reliable ever since.
    09-13-2017 11:09 PM
  7. PatG9234's Avatar
    Thanks @brianjsw
    I'll have to get my MSL from Sprint in order to mess with these settings. My phone is prioritizing band 41 over 25 and 26.
    09-14-2017 09:49 AM
  8. mj0528's Avatar
    I live close to the sticks. I'm excited to have moved to Verizon so I can actually use my phone inside. Lol
    I get 15 where with at&t I was getting around 1-2. I have the fastest home provider here as well with the fastest pkg of 5 that sometimes goes to 10.
    Ugh!!!
    09-14-2017 04:27 PM
  9. MrDDBright's Avatar
    Hello, I am a sprint user and have Samsung s8+. I used to use 90 WiFi home and out. Now i fell behind with xfinity I have found my phone to be very slow at home and in public. It like my phone was use to WiFi so much it don't know how to function without it. I tried everything I can thing to make my LTE n phone move faster. I will take it in Saturday 11/18/2017 to see what they say. Any ideal or suggestions?? ~ Chgo
    11-18-2017 12:55 AM
59 123
  1. Where is music stored on Galaxy S7 Edge?
    By davybhoy in forum General Help and How To
    Last Post: 04-24-2017, 03:46 PM
  2. My Andriod Device Manager causes malware??
    Last Post: 04-24-2017, 09:29 AM
  3. Replies: 1
    Last Post: 04-24-2017, 04:27 AM
  4. I cannot find my thread anywhere
    By Jo Lisa in forum Ask a Question
    Last Post: 04-24-2017, 03:46 AM
  5. S8+ Aod Alarm Clock
    By AC Question in forum Samsung Galaxy S8 & S8+
    Last Post: 04-24-2017, 02:28 AM
