1. Frozen Corpse's Avatar
    Your track. Everytime I pause my music, the volume will raise to an even higher level for a few seconds. I can't seem figure out what's causing the problem.
    04-24-2017 07:02 AM
  2. Golfdriver97's Avatar
    Is this the stock music player?
    04-24-2017 09:09 AM
  3. Frozen Corpse's Avatar
    Nope, I'm currently using Napster since it's only $5.99 through T-mobile. I disconnected my regular S8 and it was still doing it.
    05-02-2017 04:39 PM
  4. Mr Mendelli's Avatar
    Do your headphones have a remote and or mic on them? I've noticed on pairs with these tend to alter your audio or track settings if the wire begins to short-out.
    05-02-2017 05:21 PM
  5. Golfdriver97's Avatar
    @Mr Mendelli might have a good idea. I would also try a different music player in case the one you are using has a bug.
    05-03-2017 08:56 AM
  6. Mr Mendelli's Avatar
    That is also a possibility. I recommend BlackPlayer EX, it costs $2.95, but entirely worth it.
    05-03-2017 03:46 PM
  7. Frozen Corpse's Avatar
    With Bluetooth off, no headphones, I can hear the volume fluctuate to a higher volume for a second...
    05-08-2017 03:49 PM
  1. Replies: 2
    Last Post: 05-03-2017, 07:48 AM
  2. P10 Plus unusable after unlock
    By Naganom in forum Huawei P10 & P10 Plus
    Last Post: 04-28-2017, 11:44 AM
  3. P10 Plus unusable after unlock
    By AC Question in forum Huawei P10 & P10 Plus
    Last Post: 04-24-2017, 02:23 AM
  4. P10 Plus unusable after unlock
  5. Why does my phone say call volume when I am not in a call.
    Last Post: 04-24-2017, 01:47 AM
