durandetto
Trusted Member
What in the world is the Zagg Wet? Is this the Zagg HD film protector?
Yes. Its a wet install which is why its referred to as zagg wet.
I'm using the Verizon screen protector. So far, I haven't had any problems. I've tested it with Incipio (my current case), as well as the Otterbox Symmetry and Commuter cases and a couple other cases with no problems.
Generally the cases with integrated protectors affect the touch sensitivity of curved screens. Because it's attached to the case, not the phone, you get a slight gap especially on the edges.
This is the Wet Zagg I got...Is this the Zagg HD we are talking about?
I'm thinking about trying this one out. It's not cheap but it was custom made for the S8+.
https://www.moshi.com/ionglass-screen-protector-galaxy-s8-plus
Check this video:
I use Ghost Armor (Ghost Armor | Shields Screen Protectors Scratchproof Skins) case-friendly variant in combination with the Spigen Liquid Armor (https://www.amazon.com/Spigen-Liqui...ag=hawk-future-20&ascsubtag=UUacUvbUpU5784003). It works fanstasic. The fit is spot on, no edges being pushed up or anything. Nearly 100% coverage on the front. If you get the Ghost Armor regular screen protector it covers 100% of the front of the phone. Back cover will cover nearly 100%.This might sound crazy, but I'm obsessing about this screen and keeping it protected. My inability to find a suitable screen protector might force my hand into returning it. (And I cannot stand those wallet-type cases that force one to use two hands.) It's the first smartphone I've had go this long without a screen protector. The sand and gravel are taunting me, just waiting for me to drop my guard and scratch up this beauty. My name is sangs - and I have a problem. Help me Obi Wan Kenobi. You're my only hope.
I just made a post with this same problem and I found another case that might be to some peoples liking. The same company made this case for the Fire 7 which I bought and fits great.
https://www.amazon.com/SUPCASE-Sams...ag=hawk-future-20&ascsubtag=UUacUvbUpU5784027
