1. beri's Avatar
    So on my S8 I have my Gear S3 connected but it keeps dropping every once in a while and doesn't reconnect, or if I go out of range and back it doesn't reconnect. Does anyone else have this issue or know of any fixes? I already unpaired and reconnected, I also factory reset my Gear S3 and same issue.
    Thanks
    04-25-2017 11:30 AM
  2. scott_0's Avatar
    Ive noticed greatly reduced range with the S8 and my Gear S3, thats my only gripe, mine looses connection much sooner (shorter distance) than my S7E did, but it always reconnects
    04-25-2017 12:25 PM
  3. dmoss7's Avatar
    I haven't noticed any distance decrease with my s2 classic. I actually feel as though my range has increased a little bit. But it always reconnects when it gets back in range.
    04-25-2017 01:12 PM
  4. RicKaysen's Avatar
    Thanks
    Totally unscientific but when I leave my desk at work, my S3 signals a disconnect at approximately the same distance down the hall. My Level U Pro on the other hand has become unusable with serious popping and crackling noises. It's not because of the new phone since it did the same thing with my S7 Edge.
    04-25-2017 01:32 PM
  5. jhmccl's Avatar
    My S8 initially connected to my 2015 Subaru Forester on the first day, but now shows No Device whenever I try to connect.
    The phone shows Car Media as available but will not connect. My old phone connected very easily but quite often stopped playing music. I am ready to return the phone over this issue.
    04-25-2017 01:46 PM
  6. Kalvin Kerns's Avatar
    Thanks
    Happened this morning to me. Bummed.
    04-25-2017 02:26 PM
  7. Jonnny4's Avatar
    I can go about the same distance with my Gear s3 as I did on the Note 5. Some cases can cause problems.
    05-03-2017 01:29 PM
  1. Bluetooth Volume issue since Nougat update
    By PatrickMJ in forum Samsung Galaxy S6 edge+
    Last Post: 03-18-2018, 09:13 AM
  2. Edge App issues - Column vanishing from apps
    By Teh Cheshire in forum Samsung Galaxy S8 & S8+
    Last Post: 07-17-2017, 09:19 AM
  3. Why is my Moto Z Bluetooth not working?
    Last Post: 06-07-2017, 05:40 AM
  4. Questions/ Issues with G6
    By nicjimbass in forum LG G6
    Last Post: 05-03-2017, 09:34 AM
  5. T-Mobile Galaxy S8 VOLTE Issue T-Mobile S8+
    By mikea3000 in forum Samsung Galaxy S8 & S8+
    Last Post: 05-01-2017, 11:24 PM
