1. J4To's Avatar
    Hello all,
    I'm coming from an iPhone and I'm having trouble understanding how Samsung has implemented Nougat style notifications.
    On my last Android device I could still get "pop-up" or "heads-up" style notifications for all apps.
    Right now, I only get the "little pill" Samsung notifications for the stock Messages app and Google Voice. For all other apps, I only get an icon in the status bar along with the sound/vibration. This even goes for the stock Google apps (Gmail, Google Now, etc), I only get an icon but no pop-up.
    Is this normal?
    I used to mess around a lot with custom ROMs back in the day so maybe I messed up an "adb shell" setting that is somehow carrying over (?).
    Is this how it works on your device? Thanks
    04-25-2017 03:51 PM
  2. TabGuy's Avatar
    I use Popup Notifier to do exactly what you need. Give it a try. You can be very selective on what apps you let pop up onto the screen.
    https://play.google.com/store/apps/d...ificationslite
    04-25-2017 04:06 PM
  3. J4To's Avatar
    Thanks, I'll give it a try!
    So, are notifications the same on your device (with stock settings)? Just an icon in the status bar for the majority of apps?
    04-25-2017 04:20 PM
  4. LeoRex's Avatar
    Notification types are, by default, at the app's discretion. There are 5 levels of notifications for in 7.0...
    1) SHUTUP! LEAVE ME ALONE!!!!
    2) No full screen interruption, peeking, sound or vibration. Notification is at the bottom of the list and is not seen on lock screen or status bar
    3) No full screen interruption, peeking, sound or vibration. But it will be seen in the status bar and lock screen
    4) No full screen interruption and peeking. Sounds and vibration allowed
    5) Always peek, no full screen interruption
    6) Always allow full screen interruption, notification comes in at highest priority, etc.... basically an ambulance going through traffic.
    Now, this is all handled by the app, but you can go in and modify them, of course (7.0 has advanced notification controls). But most apps usually go with levels 4 or 5.... 4 is where you might get pinged and see the icon in the notification shade but no drop down (peek). Only high priority notifications get 5 or higher.. things like
    So it's a per app basis.
    I don't know if Samsung opened up the advanced notification controls on the S8... they DID on the S7's 7.0 build, so it might be. Someone with one of them might be able to point you to them.
    J4To likes this.
    04-25-2017 04:51 PM
  5. J4To's Avatar
    Ahh, I see. So it's normal for apps like Gmail to be set a #4 ?
    If I remember correctly, there used to be a way to set the priority level of notifications, but Samsung seems to have removed it (at least on the S8). If anyone knows how to access the System UI Tuner, that might solve things.
    Thanks for the explanation!
    04-25-2017 05:06 PM
  6. LeoRex's Avatar
    Yep... I don't think GMail is considered a priority notification. I think that's really reserved for messaging (SMS) and phone calls.
    You are 100% correct... the notification controls are often buried in the System UI Tuner. BUT... OEMs might have moved them. I'm playing around with my wife's new G6 and they took those settings and moved them into the main notification area. I think Samsung moved them into a similar location on the S7. That slider is really just Google's stock implementation.
    J4To likes this.
    04-25-2017 10:04 PM
  1. Dilemma-iPhone 7 or Galaxy 8
    By marie49 in forum Ask a Question
    Last Post: 01-10-2018, 02:50 PM
  2. can't seem to play music from my s5
    By AC Question in forum Samsung Galaxy S5
    Last Post: 04-26-2017, 02:12 PM
  3. Replies: 0
    Last Post: 04-25-2017, 03:46 PM
  4. Backup help
    By wallstreet123456 in forum Samsung Galaxy S8 & S8+
    Last Post: 04-25-2017, 02:59 PM
  5. can't seem to play music from my s5
    Last Post: 04-25-2017, 02:02 PM
