1. jcp007's Avatar
    How many of you experienced edge panels for the first time?
    How many panels are you using? Which panels are you using?
    04-25-2017 11:35 PM
  2. blaine07's Avatar
    I guess I just haven't found a outstanding use for it... Yet. It is very cool I'll say 😐
    04-25-2017 11:40 PM
  3. lrrowley's Avatar
    I've never really used it on the S6e, S7e and Note 7, and the reason why I have changed now is because of all the third party panels you can get. I bought one for my Spotify playlists and it is awesome. I also like how they've added an edge panel for the Note 7's screen capture features. I like the contacts as well.
    04-25-2017 11:52 PM
  4. lgossin's Avatar
    First time, came form a S5, do not see a reason for it. Frankly I would prefer a flat screen and the a simple case to protect the phone. I had a TPU case on my S5 and it had jsut enough lip to protect it when dropped, I did customize the edge apps, really haven't used it much
    04-26-2017 11:21 AM
  5. bandofbrothers2112's Avatar
    I've used edge panels on my s7 edge so will on my s8.
    People edge.
    Quick Notes.
    Tools panel.
    04-26-2017 11:26 AM
  6. Byron Hinson1's Avatar
    I find it cool to show off. But never use it!
    04-26-2017 11:29 AM
  7. paridge's Avatar
    Used it on 6 edge, extensively on 7 edge, and now on 8+. I live on the apps edge. It's a nice quick launcher, especially when you're in another app. The tools edge is useful too. I have a couple other edge apps set up, but I don't use them as often.
    04-26-2017 12:13 PM
  8. alphabets's Avatar
    I use it for favorite apps, people, sports and weather so far.
    The only issue I have is the edge display not lighting up for all of my notifications. I have the settings marked correctly, just still not working for all notifications.
    04-26-2017 12:27 PM
  9. Nubwy's Avatar
    I tried it once but I found it redundant to my AOD icons. Its neat but it's not all that useful.
    04-26-2017 12:47 PM
  10. billsterjito's Avatar
    I don't use it that much so far but I have it set up
    News
    People
    Apps
    Music-(this is the one I use the most)
    04-26-2017 01:01 PM
  11. EMGSM's Avatar
    I've used it since the S6 edge. If helps me keep the home screen clutter free. I'm currently using 5. I use apps edge,internet, people edge, smart select and device maintenance
    04-26-2017 01:09 PM
  12. bassplayrguy's Avatar
    I am forcing myself to use it and give it a shot. I've never had it before. I am really liking it.
    04-26-2017 01:15 PM
  13. jd03ctd's Avatar
    Is there a way to move it to the left edge? I checked the setting and did not see a toggle.
    04-26-2017 01:20 PM
  14. AlphaVictor87's Avatar
    I've used it on my S7E. I mainly use the apps edge and data usage panels. I also have the people edge set up but don't used it much.
    The apps edge is honestly the best option. Having a set list of apps that you can access from any screen without going to the home screen is so nice.
    04-26-2017 01:25 PM
  15. tcdude's Avatar
    I use them for a handful of things like certain tasks and certain apps and I use it also to check my data consumption, I have limited data so I need to keep my eye on it and it's convenient because I can scroll it at any time even during a video I just turn it to portrait and slide the edge panel to see how much data I used
    Basically I have it for a few basic things I don't have too may edge panels
    04-26-2017 01:25 PM
  1. Galaxy S7 Edge Battery Drain - Android System and Android OS
    Last Post: 06-22-2018, 04:50 PM
  2. Replies: 6
    Last Post: 05-14-2017, 12:46 PM
  3. Should we buy Samsung note edge or Moto G5 Plus - Wefix365
    By wefix365llc in forum Ask a Question
    Last Post: 04-27-2017, 12:52 PM
  4. Turning off edge menu per app?
    By stormed in forum Samsung Galaxy S8 & S8+
    Last Post: 04-25-2017, 03:43 PM
  5. O2 S7 Edge update UK
    By spinachie in forum Samsung Galaxy S7 edge
    Last Post: 04-25-2017, 03:16 PM
