1. Freakster1's Avatar
    When I try to mirror my phone to my Samsung TV it doesn't seem to want to connect. The tv will show up as a device in the Bluetooth menu but won't connect when I select it.. Any thoughts?
    04-26-2017 12:07 AM
  2. certifiedkj's Avatar
    Mine mirrors to my Samsung TV with no problem. I can also mirror the TV and just the audio of the TV just fine. Did you use Samsung Connect to link the devices?
    04-26-2017 12:19 AM
  3. anon(238680)'s Avatar
    Couple other threads going on this. Look for Smart Connect and Quick Connect in this forum. I believe you need that app to mirror.
    04-26-2017 12:20 AM
  4. jacker's Avatar
    You have to use Samsung connect like certified said.
    And be on WiFi.
    04-26-2017 12:45 AM
  5. EMGSM's Avatar
    I use Samsung Connect and it works fine for me.
    04-26-2017 12:49 AM
  6. Freakster1's Avatar
    Thanks for all the replies. I found my solution in another thread. I just need to enable Smart View in the drop down menu.
    04-28-2017 12:24 AM
  1. Possible to change Google Assistant from home button?
    By Kirk Maluo in forum Samsung Galaxy S8 & S8+
    Last Post: 04-26-2017, 05:18 PM
  2. How to unlock sprint Samsung Galaxy s7 edge
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 04-26-2017, 08:55 AM
  3. Samsung S5 SM-G900V stuck in boot forever with blank screen
    By AC Question in forum Samsung Galaxy S5
    Last Post: 04-26-2017, 08:27 AM
  4. How I fixed my galaxy s8 edge lighting issue
    Last Post: 04-26-2017, 06:16 AM
  5. Replies: 1
    Last Post: 04-26-2017, 12:25 AM
