Well crap, I don't have that at all. Mine calls my voicemail.
I'm on T-Mobile as well so I should also have it.Pretty sure it depends on the carrier, no?
Only if you are subscribed to Visual Voicemail. You might also need to download T-Mobile's Visual Voicemail app (can't remember if it was included with the S8 or if it just prompted you to download it). if you are a subscriber (which would also answer the OP's question if that's the case).
I have T-Mobile also and the T-Mobile Visual Voicemail app works. However in the dialer app, when I click the voicemail my S8 also just calls voicemail.
One thing I don't have though is the separate Voicemail to Text add on. It looks like that's the key to get the Samsung Visual Voicemail to work.
