1. AC Question's Avatar
    Hi guys, got my S8+ 2 days ago. Phone works fine but when I charge it I've noticed/heard the notification, of when you plug in the charger, go off. When I've checked the Phone, when its happened, it's at 99% and then proceeds to 100%.... its happened every single time ive charged the phkne. Just wondering if anyone has encountered the same issue?
    04-26-2017 01:01 PM
  2. Aquila's Avatar
    It's just alerting you that the battery is full.
    04-26-2017 01:22 PM
  3. PJRed2008's Avatar
    Yep. You can turn that off in settings if you wish.
    04-26-2017 01:25 PM
  4. Licious87's Avatar
    But it's still at 99% when I hear the notification... my Note 4 and S7 edge never did that, reached 100% and the light went green... on my S8 + it's still red when the notification sounds...
    04-26-2017 01:58 PM
  5. PJRed2008's Avatar
    But you said in your OP that it then turns to 100%. I would assume there's a small lag between what triggers the notification and what controls the LED.
    04-26-2017 02:23 PM
  6. Licious87's Avatar
    Sorry I should have worded it differently, I meant to say that when this happens, it eventually charges up to 100% but takes a further 5-10mins to do so
    04-26-2017 03:22 PM
  1. Hi, my backup and restore manager has stopped working.
    Last Post: 04-26-2017, 01:38 PM
  2. Phone vibrates on incoming calls but no ring sound
    Last Post: 04-26-2017, 01:34 PM
  3. Replies: 1
    Last Post: 04-26-2017, 01:32 PM
  4. Media continues to play on bluetooth during phone call.
    By jcthorne#AC in forum Samsung Galaxy S8 & S8+
    Last Post: 04-26-2017, 01:23 PM
