1. BlackSheriff84's Avatar
    Within Cortana you can click meetings then it will ask you to connect your calendar.
    I have connected my outlook calendar but when i check my day through cortana it says i have no meetings even though i do.
    Is anyone experiencing the same issue when using outlook as there default calendar?
    04-27-2017 06:04 AM
  2. wpfan86's Avatar
    Yes! I've never really gotten Cortana to work properly with my Outlook calendar, which is insane since thy are both Microsoft services.
    I was having issues with location-based reminders as well, so I uninstalled and reinstalled Cortana. Now, I get a message in Cortana suggesting I connect my calendar. When I attempt to connect Outlook, it tells me Outlook is already connected. It makes no sense.
    04-27-2017 09:33 AM
  3. BlackSheriff84's Avatar
    exactly my issue, hopefully it gets relsolved soon!
    04-27-2017 07:44 PM
  4. BlackSheriff84's Avatar
    Heres another Cortana issue I am facing
    I have rempped my Bixby button to open cortanna using bxActions app which is great
    and also in main settings you can also change the home button (long hold) to open cortana instead of google assistant which is also great.
    Whats not so great is now the bixby button and home button (long hold) do excatly the same thing.
    What I really want is for the home button (long hold) to open Cortana Mic shortcut!
    Any one know a solution?
    04-27-2017 07:53 PM
  5. Tunno79's Avatar
    I am glad it's not just me. I have the exact same problem. I hope it get's resolved. They are both MS services and the fact it doesn't work is very surprising.
    Recent convert from a Lumia 950 to Oneplus3T
    04-28-2017 12:49 PM
  6. peconicgp's Avatar
    while it has never worked for me, i was frustrated once again that this doesn't work for me now on my new S8+ either. I disabled the samsung calendar app and use outlook but can't get cortana to show my calendar. Is there some setting that needs to be updated elsewhere?
    04-28-2017 03:25 PM
  7. BlackSheriff84's Avatar
    Intresting, how did you manage it? I am unable to to diable the stock calendar app.
    04-28-2017 09:33 PM
  1. Replies: 2
    Last Post: 04-29-2017, 01:09 PM
  2. System files taking up 90% of space! Help!
    By AC Question in forum Samsung Galaxy S5
    Last Post: 04-27-2017, 04:12 AM
  3. System files taking up 90% of space! Help!
  4. Replies: 0
    Last Post: 04-26-2017, 08:42 PM
  5. Please help with a tablet getting a "dm-verity verification failed
    By Lgatesws in forum Samsung Galaxy Tab 2
    Last Post: 04-26-2017, 02:02 PM
