05-01-2017 06:05 PM
28 12
tools
  1. illdini's Avatar
    Why put apps on the SD card at all? Even after downloading several GB of Oculus apps/content for VR, I have 39.2 GB of internal storage left.
    05-01-2017 04:16 PM
  2. JLD94's Avatar
    Why not? Is it somewhere in writing that apps should not be put on a SD card? Please show me information from Samsung or Android as an OS that you are not suppose to do that? I never had a problem with it on my Note 4, so why is it a problem now?
    Altering the way you use something because it is not working correctly that way = broken. Unless of course it was not designed to be used that way. However in this case I believe it was, otherwise it would not be an option to do so.
    The larger problem here is the random restarting. It happens probably 4-5 times a day. It's happened twice in the middle of using it
    05-01-2017 04:36 PM
  3. Gayle Lynn's Avatar
    I read about then ran a disk test to compare different phones.
    SD card with 80-90MB us fine for media but I want apps using the .uch faster internal storage.
    05-01-2017 06:05 PM
28 12
  1. Why my phone isn't fast charging?
    By AC Question in forum Samsung Galaxy S8 & S8+
    Last Post: 03-17-2018, 12:34 PM
  2. camera focus problem using apps
    Last Post: 06-07-2017, 05:56 PM
  3. Replies: 2
    Last Post: 04-27-2017, 08:41 PM
  4. Replies: 0
    Last Post: 04-27-2017, 01:44 PM
  5. Corrupt android os or hardware problem?
    By AC Question in forum Moto G4 Plus
    Last Post: 04-27-2017, 01:43 PM
