1. edhawk's Avatar
    Wifi speeds on my S8+ are horrible to compared to my old IPhone 7+.
    I have google fiber, wifi speeds on
    IPhone 7+ 551 down, 367 up
    Galaxy S8+ 35 down 44 up
    exactly same testing location, 1 min apart. both connected to 5g. Rediculously low wifi speeds ,-20170428_122753.jpgRediculously low wifi speeds ,-screenshot_20170428-123222.jpg
    04-28-2017 12:38 PM
  2. Almeuit's Avatar
    exactly same testing location, 1 min apart. both connected to 5g. Click image for larger version.
ID:	258551Click image for larger version.
    Hm.. not sure. Something isn't working right with either the phone or your phone not liking your router. The S8 is definitely capable.
    04-28-2017 12:51 PM
  3. Ageeb's Avatar
    exactly same testing location, 1 min apart. both both connected to 5g.
    The phone is definitely capable of better. Take a look at this thread for more examples.
    04-28-2017 01:07 PM
  4. Gayle Lynn's Avatar
    Hum. Make sure cellular is off for both. A reboot and wait for system to quiet down.
    04-28-2017 01:12 PM
  5. theelite1x87's Avatar
    Something is wrong somewhere. My internet isn't as fast as yours but I get 70mbps on my Wi-Fi with S8+, which is my max internet speed.
    04-28-2017 04:00 PM
  6. Almeuit's Avatar
    What kind of router are you using OP ? I have Google WiFi and at home on 5 GHz I get good speed on my AT&T fiber.
    04-28-2017 04:49 PM
  1. wifi problem
    By Rahul Kumar70 in forum Android 6.0 Marshmallow
    Last Post: 04-28-2017, 11:51 AM
  2. Unable to remove Swift wifi
    Last Post: 04-28-2017, 05:07 AM
  3. my wifi is unvailable adress
    Last Post: 04-28-2017, 02:01 AM
  4. PdaNet WiFi HotSpot & Nougat update
    By James Changstein in forum Axon 7 & Axon 7 mini
    Last Post: 04-27-2017, 07:21 PM
  5. Wifi Timer on Galaxy S5 does not end Wifi
    By Wijono in forum Samsung Galaxy S5
    Last Post: 04-27-2017, 03:25 PM
