08-14-2017 11:08 PM
188 1234 ...
tools
  1. durandetto's Avatar
    I'm using the Samsung card from the note 7 and no issues yet. At least not that I've noticed and o would have to use my pin if it happened.
    04-28-2017 07:29 PM
  2. scott_0's Avatar
    using a 64g SanDisk, no issues here........
    04-28-2017 07:30 PM
  3. ThrottleJohnny's Avatar
    If folks are within their 14 day return period, I'm not sure why they're sitting around discussing it in a forum. Return it ASAP and get a replacement or a different phone.
    tube517 likes this.
    04-28-2017 07:34 PM
  4. donm527's Avatar
    Well reboots may not be necessarily hardware... could be software and need to figure out what. Could be a conflict with an app... the the 2:1 screen size you could have issues that cause crashes until apps are updated. It could be updates or security patches causing new conflicts that didn't happen with preload. Or an app got updated and could be a popular app or not and it's causing the crash.
    The issue is if it is sw. If Its with an app you can work around by uninstalling it or waiting for update. if it requires an OS update then you wonder with the way you have to wait for carriers to push updates if you'll ever get it.
    Then if it's hardware then...
    04-28-2017 07:43 PM
  5. ol_jackburton's Avatar
    no issues here, using the sd card from the $99 bundle. had the sd card in since i got the phone (4/20)
    04-28-2017 07:49 PM
  6. Dubss's Avatar
    S8+ sprint no reboots
    04-28-2017 07:58 PM
  7. songbae's Avatar
    1st reboot today. Screen greyed out, high pitched whine, then shut off. If it happens more, I'll return it.
    04-28-2017 09:27 PM
  8. nuangel2's Avatar
    T Mobile s8+ for a week with SD card no reboots here
    04-28-2017 09:39 PM
  9. Mr_Spencer's Avatar
    I made a thread about this on day 2 or 3 after receiving the phone. So basically the 21/22. My phone kept rebooting throughout the day. Since then it has not happened again.
    VW Maverick likes this.
    04-28-2017 10:14 PM
  10. Viscomi4444's Avatar
    Did you delete anything or change anything in the settings, etc?
    04-28-2017 10:32 PM
  11. bandofbrothers2112's Avatar
    You guys having these issues have you tried removing the Sd Card, reformatted it as a last resort or tried another.
    That's If of course this is connected to a card.
    There's so much this could be attributed to unfortunately and imo is a process of stripping back what you've put on the phone.
    04-28-2017 11:22 PM
  12. Jacy Hung's Avatar
    I have the T-Mobile S8, not sure what happened but today I enabled the Mobile HotSpot and for some reason the phone shut off..
    It didn't boot itself back up and holding the power button or power + volume down didn't do anything. I plugged the phone into my portable charger (luckily I had one on hand as I was out at the time) and the phone began to charge (the phone was at 29%), and then pressing the power button booted it back up.
    04-28-2017 11:27 PM
  13. bandofbrothers2112's Avatar
    Just another thought.
    You guys that are having these issues ~ was the phone supplied by a Network or via Samsung direct.
    I'm just wondering as in the Uk a network will test / play around with firmware before allowing Samsung to send out patches and firmware so it could be conflicting somehow on the phone.
    04-29-2017 12:52 AM
  14. omgitselaine's Avatar
    I was watching a movie late last night and my S8+ suddenly shut down ???
    Screen went entirely black so I held the power and I believe one of the volume buttons down for a few seconds until powered back up ??
    It was a little scary since I've never owned a phone that did that ........ I had thought perhaps I uummmmm shouldn't​ be watching what I'm watching ahem ahem ???
    Hopefully it's an isolated incident ??
    Mr_Spencer and 1naturalace like this.
    04-29-2017 03:43 AM
  15. spridell's Avatar
    - Samsung is aware of this issue (according to the Samsung official boards) so if they are aware its big enough problem that they are looking into
    - People have reported they have returned the phone and got a new one and still having the problem.
    If you do a quick google search for S8 reboot, there are a bunch of top tech sites now reporting on this. This is NOT good news for Samsung after the note 7 problem
    I have only had it once so far. So lets see what happens
    04-29-2017 10:39 AM
  16. the_munc_e's Avatar
    My contacts app glitches when I try to edit a contact and I have to force stop it and restart it.
    04-29-2017 11:53 PM
  17. EMGSM's Avatar
    I've had the T-Mobile version for about 11 days now. I have an sd card in mine and I have had no such problems.
    04-30-2017 02:34 AM
  18. Ventura726's Avatar
    I have the T-Mobile S8+ and it just did it for the first time about an hour ago.
    04-30-2017 02:42 AM
  19. bandofbrothers2112's Avatar
    May not be connected but do you have a Sd Card fitted and what make & Capacity.
    04-30-2017 02:58 AM
  20. aokusman1's Avatar
    Mine has done this but so did my s7 and my iphone 6s as well.
    04-30-2017 04:45 AM
  21. Gary02468's Avatar
    My S8+ started doing occasional spontaneous reboots at the moment I used the iris scanner. Previously, the scanner had occasionally failed and not worked again until I manually rebooted. I exchanged for a new S8+, and we'll see if I get the same problem. (I do have an SD card, 256GB Samsung Evo+ from last year's Note 7 promotion. That worked fine in my Note 7s and in my S7e, so I doubt it has anything to do with the problem.)
    04-30-2017 07:04 AM
  22. blackbird666's Avatar
    Been using mine for 10 days now, no reboot problems!
    Viscomi4444 likes this.
    04-30-2017 07:22 AM
  23. Ca_lvn's Avatar
    So now it's having bootloop issues like LG phones do?
    Also it seems the Samsung micro SD cards always seem to be causing issues. I've seen post on here talking about their Samsung Micro SD cards dying on them.
    My promo 256g card from Samsung from the N7 died on me had to throw it away barely used, was only storing media on it not even keep in the phone
    04-30-2017 07:52 AM
  24. mhettrich's Avatar
    No problems with my T-Mobile S8+.
    04-30-2017 07:58 AM
  25. TheDonJ77's Avatar
    Guess I'll be holding on to my S7 edge for a little while longer till this gets cleared up. No biggie, still loving my S7E
    04-30-2017 08:25 AM
188 1234 ...
  1. Samsung T-320 looking for either lollipop or marshmallow??
    By thomtwo in forum Samsung Galaxy Tab S3
    Last Post: 04-30-2017, 05:35 PM
  2. Why is my camera not working well indoor?
    Last Post: 04-29-2017, 04:15 PM
  3. Samsung DeX Station - stand alone or
    By stonefox in forum Ask a Question
    Last Post: 04-29-2017, 09:09 AM
  4. Why my phone stopped working after been charging?
    By AC Question in forum Samsung Galaxy S6 edge
    Last Post: 04-28-2017, 09:47 PM
  5. GO Notification colors or icon not showing up on S8
    By AC Question in forum Samsung Galaxy S8 & S8+
    Last Post: 04-28-2017, 12:49 PM
