08-14-2017 11:08 PM
188 ... 34567 ...
tools
  1. y2jdmbfan's Avatar
    Was this within 14 days?
    05-15-2017 11:02 AM
  2. y2jdmbfan's Avatar
    Well i returned mine to Best Buy yesterday for a exchange and that was brutal for a hour and a half i was there till they could figure out how to do it. Finally left with a new 1 as i returned mine die to 2 lock ups and 1 time it froze and had to hold power button and volume button till it rebooted. just a hour ago while on charger it rebooted and i have not even put a SD card in it yet. I think i am going to put my 256G card in it and see what happens. But i do not plan on another 90 minute trip to Best Buy unless it does it again a few times.
    05-15-2017 11:02 AM
  3. theelite1x87's Avatar
    Got my 256GB SD card from Samsung. It's been installed for a couple weeks now. No issues so far
    05-15-2017 11:27 AM
  4. JLD94's Avatar
    its the apps installed on sd, put them back on internal and no reboots. ****ty though... rather have all my stuff on the sd card to save space for computing...
    That's my problem with this.... you reason to yourself that may 'fix' it but then it's not really a fix because someone has to use it to a way contrary to the way it was designed or the way you use it.
    It's like saying 'the a/c in my house feels like it's coming out when I shut all the vents but one'
    05-15-2017 12:15 PM
  5. dego locsta's Avatar
    I agree, although I have submitted and took all my apps off the sd card because I felt like between that and the sd card card mounting and unmounting, it was eating away at my battery, they really need to find a fix for this A.S.A.P.
    So far so good since I took my apps off the sd card earlier today.
    05-15-2017 10:38 PM
  6. cardboard60's Avatar
    Have you taken this phone back to the carrier ?
    05-16-2017 07:15 AM
  7. Kalvin Kerns's Avatar
    Have you been to my house?
    05-16-2017 10:51 AM
  8. Gary02468's Avatar
    Everyone having this problem should report it directly to Samsung so they know how widespread and urgent it is. Samsung monitors and participates in the following forum:
    https://us.community.samsung.com/t5/...ers/bd-p/GS8QA
    05-17-2017 06:00 AM
  9. boricuacaddy's Avatar
    Well, I was not having a restart problem until yesterday when I moved apps to the SD card. So, far it restarted twice. If it continues, I will move the apps back. But to me this defeats the purpose on having an SD card. Hopefully Samsung sends out an update that will fix this bug.
    05-17-2017 09:11 AM
  10. JLD94's Avatar
    It's been 4 weeks so far with no update to fix this.....who knows when or if it will get fixed.
    05-17-2017 03:45 PM
  11. JLD94's Avatar
    One moderator on there says he's trying to get it to the 'right' person..... made it sound like he's not taken seriously. When more protested about it another moderator said 'samsung is aware and working on it' so I'm not sure at this point what's going on...but it doesn't seem like it's being handled well.
    05-17-2017 03:47 PM
  12. NJ Fred's Avatar
    Samsung should hang its head in shame. First, the Note 7 debacle. Now, this.
    As I wrote in a different thread, consumer confidence should be shaken. All indicators point to inadequate quality control and pre-release testing. It started with the red-tint issue and now the rebooting.
    This is Samsung's bag of bones. And they should be reaching out to the consumer with either a guaranteed fix or offer of full refund no matter where the S8 was purchased. Their silence on this matter should prove troubling to intelligent consumers. And it should prove an indelible stain on the Samsung brand name.
    05-17-2017 04:33 PM
  13. Ca_lvn's Avatar
    They can't own a setback or failure with QA there still trying to recover from the N7
    05-17-2017 05:24 PM
  14. Qc_Anubis's Avatar
    Well last time it was Lg who had a bootloop issue guess they passed down that problem to samsung XD
    No issues on mine either not using any sd cards
    05-17-2017 06:27 PM
  15. 1naturalace's Avatar
    I have a couple random reboots on my S8. I do have a SD card installed.
    05-18-2017 06:39 AM
  16. Wahoolewi's Avatar
    I have had the Galaxy 8 + 4 < one week and I did not do a re store from my previous note 5I started from scratch and the phone reboots to the white screen about every 2 hours I do not have an SD card I have all of the face recognition in all a special features turned off and it still does this about once every 2 to 3 hours . I did the master reset updated all of the system software and it still did the same thing. Space I think I have tracted to the Nova launcher I'm just using the basic easy launcher and has been online for 4 hours and have not had the reboot a problem
    05-18-2017 11:46 AM
  17. Gary02468's Avatar
    Plenty of us have had random restarts on the S8 without even installing the Nova launcher.
    It's a good idea not to post the last thing you tried until much more than a few hours pass without incident. After a few days without incident, you might have good reason to suspect you've got a solution.
    05-18-2017 12:11 PM
  18. CincyGuy's Avatar
    S8, no SD card. My phone has rebooted 3-4 times over the past week when I plug into my car's USB and hit the Android Auto icon on my car screen. Nothing happens on the car screen, and when I look down at the phone I see the Samsung logo appearing because it is rebooting. I have to unplug the phone from the USB cable and type in my pin to unlock it, then plug it back into the car for AA to load up.
    05-18-2017 12:29 PM
  19. Dubss's Avatar
    No reboots here I've had the phone since launch
    05-18-2017 12:49 PM
  20. hdhuntr's Avatar
    Same for me and same since I added the 256GB card over a week ago.
    05-18-2017 01:12 PM
  21. dego locsta's Avatar
    Put applications on the SD card, and you will get the reboot probably. Otherwise the apps themselves run flawlessly off the SD card, it's just the unmounting and mounting and reboots which makes my card useless for anything other than pics and movies.
    05-18-2017 02:22 PM
  22. Prince_Poppycock's Avatar
    I got the S8+ at launch. I installed an SD card on it about two weeks ago. I have only moved pictures, videos and music to the card. I've had no reboot issues.
    05-19-2017 07:01 AM
  23. jeffmd's Avatar
    So is anyone getting bootloops who has not moved apps to the sd card? Seems like that is the issue, and nothing like lg's.
    05-19-2017 08:20 AM
  24. JLD94's Avatar
    On Samsung community pages, people are calling and still getting techs "I have not heard of this".....uh huh. At this point Samsung may have lot me.... after my last 4 phones being Samsung the S8+ that I returned because of this issue will probably be the last
    05-19-2017 08:27 AM
  25. ThrottleJohnny's Avatar
    I haven't had this issue either.
    05-19-2017 08:52 AM
188 ... 34567 ...
  1. Samsung T-320 looking for either lollipop or marshmallow??
    By thomtwo in forum Samsung Galaxy Tab S3
    Last Post: 04-30-2017, 05:35 PM
  2. Why is my camera not working well indoor?
    Last Post: 04-29-2017, 04:15 PM
  3. Samsung DeX Station - stand alone or
    By stonefox in forum Ask a Question
    Last Post: 04-29-2017, 09:09 AM
  4. Why my phone stopped working after been charging?
    By AC Question in forum Samsung Galaxy S6 edge
    Last Post: 04-28-2017, 09:47 PM
  5. GO Notification colors or icon not showing up on S8
    By AC Question in forum Samsung Galaxy S8 & S8+
    Last Post: 04-28-2017, 12:49 PM
