1. RicKaysen's Avatar
    I've looked trough the app notifications in settings, but I don't see Gear as an option to turn off. Does anyone know how to stop the persistent Gear notifications on my phone....getting irritating.
    04-30-2017 08:43 AM
  2. Jaycemiskel's Avatar
    I don't think you can get rid of it. It was the same way on my S7 edge. Better get used to it.
    04-30-2017 12:00 PM
  3. racedog's Avatar
    What specific notifications are you referring to?
    04-30-2017 12:25 PM
  4. scott_0's Avatar
    do you mean in the notification drop down?
    04-30-2017 02:05 PM
  5. Ca_lvn's Avatar
    I get zero notification on my phone are you referring to S health? Check the apps and phone notifications settings
    04-30-2017 03:02 PM
  6. Jaycemiskel's Avatar
    This notification.
    04-30-2017 03:33 PM
  7. keystone_56's Avatar
    Sorry to change the subject, but are you able to use s-voice to respond to text messages? Since I've went from my S7E to the S8 I've not been able to respond to text messages on my Gear s3.
    04-30-2017 03:36 PM
  8. Kalvin Kerns's Avatar
    That's just letting you know it's connected. It's not a notification.
    Ca_lvn likes this.
    04-30-2017 03:52 PM
  9. Jaycemiskel's Avatar
    It's in the notification panel. I would consider it a notification. That's what the OP is referring to though, at least that's my guess. It's a persistent device connected notification. As far as I know, you can't get rid of it.
    04-30-2017 04:04 PM
  10. scott_0's Avatar
    it's weird because I always have it too, but today it's not there, and my Gear S3 is definitely connected
    04-30-2017 04:09 PM
  11. bhatech's Avatar
    Click on that two dot thing on the right and it opens Samsung connect panel. Turn that off entirely or you can turn that off for individual devices.
    Jaycemiskel likes this.
    04-30-2017 04:19 PM
  12. Kalvin Kerns's Avatar
    Well ok... I can see your perspective, but I wouldn't consider a notification as such. It's just letting you know your Bluetooth device is connected. I don't see a problem with that remaining. In fact I would probably be concerned if they're WASN'T something letting me know it's connected.
    For the record a that "notification" only shows when I will pull the shade down.
    04-30-2017 04:26 PM
  13. PJRed2008's Avatar
    Does this mean you have to use Samsung Connect for the Gear S watches? I've got two S2s that I seldom use and haven't activated either with the S8 yet.
    04-30-2017 04:30 PM
  14. bhatech's Avatar
    http://i2.photobucket.com/albums/y22...psmxsvqvwe.png
    http://i2.photobucket.com/albums/y22...ps8ywitctu.png
    You probably turned off the Samsung connect panel which takes that notification off.
    scott_0 likes this.
    04-30-2017 04:31 PM
  15. Jaycemiskel's Avatar
    Awesome! That worked. I never really used it anymore, especially since it doesn't tell you how much battery your watch has left without clicking on it
    04-30-2017 04:33 PM
  16. bhatech's Avatar
    It's just a place where you can manage all your connections etc. You pair them via Samsung gear as usual and you don't need to bother or do anything with Samsung connect if you don't want to.
    PJRed2008 likes this.
    04-30-2017 04:33 PM
  17. Ca_lvn's Avatar
    In S VOICE when you see three dots on the right touch those and change the language to English UK and it will work, some sorta bug myself and others had the same issue it hangs up on us English for some reason
    04-30-2017 05:15 PM
  18. Jaycemiskel's Avatar
    I see your point too about the whole "notification" thing. I personally find it annoying. An actual regular notification pops up if it disconnects(that also doesn't show unless you pull the shade down but it is a real notification, so to speak). I'd rather just assume it's connected and know when it isn't. Disabling it, is exactly what I needed.
    04-30-2017 05:24 PM
  19. Kalvin Kerns's Avatar
    Cool, glad you found what you needed!
    04-30-2017 05:28 PM
  20. keystone_56's Avatar
    I have tried that also. Still no luck
    04-30-2017 06:30 PM
  21. RicKaysen's Avatar
    Except it shows up when I leave the watch home
    04-30-2017 06:45 PM
  22. CKwik240's Avatar
    My only real complaint about it was that it would have a delay after you pull down the notifications where it world extend fully. I would be autonomy for the notification I wanted to press but would end up pressing something else because it shifts everything down. I ended up turning it off. Seems redundant anyways.
    05-01-2017 11:14 PM
  1. Replies: 1
    Last Post: 05-01-2017, 04:41 PM
  2. Why does my samsung s3 screen keep going off?
    Last Post: 04-30-2017, 08:21 AM
  3. New T-Mobile free gear VR offer April 28 - May 14
    By bhatech in forum Samsung Galaxy S8 & S8+
    Last Post: 04-30-2017, 01:24 AM
  4. Gear Fit2 Calendar notifications after Nougat update
    By neo999 in forum Samsung Galaxy S7 edge
    Last Post: 04-29-2017, 10:58 PM
  5. Custom vibration for app notifications?
    By Parker Tetrick in forum General Help and How To
    Last Post: 04-29-2017, 09:55 PM
