How low do you let you battery get before seeking a charge?
I try to charge my S8+ before it gets lower than 50% :-
Everyday , hard use, charge overnight when go to bed and unplug in the morning. From 100% down to under 15% everyday , 9AM to 10PM
With lithium cells it's generally good practice to charge it well before it's dead. Deep cycling hurts them worst (going from 0 to 100). Bump charging from say 40 to 100 is better. With today's cells I wouldn't worry too much as the technology has matured a lot. Old NiCad cells suffered from a memory effect and deep charging was preferred. NiMH don't have that problem and modern low self discharge cells can generally be treated same way as lithium batts in our phones. I personally charge mine overnight and don't hit charger again until bed time. Phone gives me awesome battery life and I normally have over 50 percent left by end of day. I'll only charge it sooner if I know I'll be out late into the evening, so I make sure it's got enough juice to do whatever I need.Where did not going below a certain percentage come from?
In NiCd days that was detrimental, but was there a generation it was advantageous?
