Hey guys, is everyone receiving this update? I am with t-mobile it says the only change was screen color adjustment and after installing it now has a slider to adjust cooler or warmer screen (under advanced options you still see the RGB bars) plus now it has another slider to adjust the color of the edges only
I'm with tesco and still waiting as well. Don't know what's causing the delay but wish it would hurry up as I want to see if it does correct the problem so that I can return the phone (3rd replacement) and go back to apple if it doesn't.Mine is unlocked from the UK.
Still no update for mine even though it was allegedly released days ago.
I updated this morning as well. By moving the slider from cool to warn, I didn't see any change in the picture showing.
Also, the update changed my launcher to TouchWiz by default. When I clicked on Nova it went to Nova home screen. When I hit home again, it went back to TouchWiz home screen.
It normally asks you to pick a default when you do this. Not anymore. I had to go into Nova and manually change the default to Nova.
I noticed there was a TouchWiz Home update overnight as well.
I received 141MB update on TMobile this AM. Includes new color adjustments but security patch level remains April 1, 2017.
Same here 138.43 MB, T-Mobile S8+ version bought from Samsung.comThat's interesting. Mine was 138.43 on t-mobile S8+
I didn't have the problem but now I do after the patch.did it fix it or you didn't have the problem?
