Edge contacts
A
AC Question
For some reason my T-Mobile GS8 will not let me add any more contacts to my Edge panel. I had initially added some with no problem. Then, it started giving me a message that I cannot add more than ten contacts. The thing is, I have three open spaces left. It will not let me select any contacts--neither from all of my contacts or from the suggestions.
Any hints how to get it to work? I tried removing a contact, which means now it's simply not there.
TN Gweilo
9
I have a US Cellular GS8+ that gives me the same error as you "cannot add more than ten", but I only have six in use. Any resolve?
TN Gweilo
9
did you try clearing all of them out, turning off that edge panel, then turn it back on and try again.
Different user with USCC GS8+. Yes, I did all that and verified that Gmail/Samsung contact as well. I can delete/add, turn on edge/turn off, but it still gives same message and will not add ten contacts, but stops at 6.
adelinachau53674
