1. AC Question's Avatar
    For some reason my T-Mobile GS8 will not let me add any more contacts to my Edge panel. I had initially added some with no problem. Then, it started giving me a message that I cannot add more than ten contacts. The thing is, I have three open spaces left. It will not let me select any contacts--neither from all of my contacts or from the suggestions.
    Any hints how to get it to work? I tried removing a contact, which means now it's simply not there.
    05-03-2017 09:15 PM
  2. atremorer's Avatar
    Hmm...did this from AC on my phone and it didn't use my actual login. Hoping someone may have some insight.
    05-05-2017 11:54 AM
  3. ol_jackburton's Avatar
    did you try clearing all of them out, turning off that edge panel, then turn it back on and try again.
    05-05-2017 08:05 PM
  4. TN Gweilo's Avatar
    I have a US Cellular GS8+ that gives me the same error as you "cannot add more than ten", but I only have six in use. Any resolve?
    11-02-2017 08:50 AM
  5. TN Gweilo's Avatar
    Different user with USCC GS8+. Yes, I did all that and verified that Gmail/Samsung contact as well. I can delete/add, turn on edge/turn off, but it still gives same message and will not add ten contacts, but stops at 6.
    11-02-2017 08:55 AM
  1. Fast Charging is no longer working on S6 Edge+ after Nougat update
    By AC Question in forum Samsung Galaxy S6 edge+
    Last Post: 05-04-2017, 09:31 AM
  2. Replies: 1
    Last Post: 05-03-2017, 08:52 PM
  3. Remove my profil from contacts
    Last Post: 05-03-2017, 08:13 PM
  4. Replies: 0
    Last Post: 05-03-2017, 04:13 PM
  5. People edge problem
    By mdarch in forum Samsung Galaxy S7 edge
    Last Post: 05-03-2017, 02:26 PM
