Save big + get 3 months free! Sign up for ExpressVPN today
  1. corvette72778's Avatar
    So I bought and downloaded BK Disabler to stop the system update on my S8 so I could keep the remappable Bixby button. I searched for updates and selected them all. However, I got a notification for the system update this morning. Can anybody help? I'm on T-Mobile.
    Also if you know of a better system update Disabler app that has worked for you on the S8 a link for the download would be appreciated.
    05-04-2017 08:16 AM
  2. Golfdriver97's Avatar
    That notification is probably a direct result of disabling the software updater. I don't think you can get rid of that notification.
    05-04-2017 08:36 AM
  3. illlya's Avatar
    I got the update also.
    05-04-2017 08:55 AM
  4. illlya's Avatar
    It is an update
    05-04-2017 08:56 AM
  5. anon(238680)'s Avatar
    There are apps in the Store that can remap the button post the update. Have you looked at those?
    05-04-2017 10:31 AM
  6. corvette72778's Avatar
    I don't think the post update apps have the same functionality. I think you can do just Google now instead of Bixby. That's it. Without the update you can set the button for 3 different functions to do anything for each.
    05-04-2017 01:41 PM
  7. corvette72778's Avatar
    The app didn't post my pic of the app.
    05-04-2017 01:46 PM
  1. Looking for manual for htc one
    Last Post: 05-04-2017, 11:21 AM
  2. Replies: 0
    Last Post: 05-04-2017, 08:04 AM
  3. Replies: 0
    Last Post: 05-04-2017, 06:33 AM
