1. ags2's Avatar
    I've tried so many different things and I cannot get any reminders from any calendar I have installed. If anyone has an idea I would be so appreciative!
    05-06-2017 02:05 PM
  2. PJRed2008's Avatar
    Common problem. If you do a search for "notification" you'll see a number of threads dealing with your problem. There are numerous settings that affect notifications, one being the battery optimization settings.
    05-06-2017 03:04 PM
  3. Jason Fournier1's Avatar
    Do not disturb as well. It can make you miss alarms if you don't enable it correctly.
    PJRed2008 likes this.
    05-06-2017 03:35 PM
  1. Replies: 1
    Last Post: 05-06-2017, 08:35 PM
  2. Replies: 1
    Last Post: 05-06-2017, 08:25 PM
  3. How do I get into my clip tray
    Last Post: 05-06-2017, 01:54 PM
  4. Replies: 1
    Last Post: 05-06-2017, 01:53 PM
  5. How do I find cliptray?
    Last Post: 05-06-2017, 12:45 PM
