1. AC Question's Avatar
    I have an ITEK selfie stick with headphone connection that worked with my IPHONE and my Galaxy S5. It does not work on this phone. I have tried several solutions but the lingo is different on this phone and the changes I made with the apps I downloaded to help do not work.
    05-10-2017 08:53 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Just to be sure -- is the Volume button set as the shutter release in the Camera app?
    05-11-2017 02:01 PM
  3. Randyxxx's Avatar
    THe options I have under volume key function are:
    1. take pictures,
    2. record video,
    3. zoom,
    4. system volume
    I dont have an option for shutter release. hmmm take pictures? I think I tried that ... trying again.
    05-11-2017 04:29 PM
  4. Randyxxx's Avatar
    OK, it does not work. I even tried voice but isn't working either.
    05-11-2017 04:34 PM
  5. B. Diddy's Avatar
    There can be subtle differences in the headphone jack configuration between phones, so it's possible that plug isn't entirely compatible with the S8's. Are you certain it's pushed in all the way? Sometimes, if the jack is pretty snug, the user might not realize it's not in all the way.
    05-12-2017 10:21 AM
  6. Randyxxx's Avatar
    Yep, I checked that out thoroughly. Even took the cover off of phone to cross check.
    05-15-2017 08:30 PM
  7. Misterb's Avatar
    You sure it doesn't work properly, because someone saw you using it and beat you to a pulp with it? Lol
    james702283 likes this.
    05-15-2017 09:06 PM
  8. B. Diddy's Avatar
    Try bringing the stick to your local wireless store and ask if you can test it out on one of their S8's.
    05-16-2017 12:56 AM
  1. S6 shut off & wont come back on
    By AC Question in forum Samsung Galaxy S6
    Last Post: 05-17-2017, 03:29 PM
  2. Backing up s8?
    By JustPassin in forum Samsung Galaxy S8 & S8+
    Last Post: 05-11-2017, 09:04 PM
  3. Note 5 wont turn on, none of the resets work. Blue light is still on
    By AC Question in forum Samsung Galaxy Note 5
    Last Post: 05-11-2017, 09:11 AM
  4. Replies: 0
    Last Post: 05-10-2017, 08:52 PM
  5. Why does my phone act cRazy?
    By sarahbellied in forum Ask a Question
    Last Post: 05-10-2017, 07:35 PM
