1. LineKill's Avatar
    It will only fast charge when the screen is off, not if you are using it or even if the screen is on. If you are in a hurry and want to do a quick charge, make sure you are not using it. Does this matter to you?
    Phone Arena
    A note to all Galaxy S8 users: fast charging only works while the screen is off
    Phandroid
    http://phandroid.com/2017/05/11/sams...arge-problems/
    05-12-2017 04:56 AM
  2. Tim1954's Avatar
    That would prevent overloading the charger, it's trying to fast charge the battery on top of lighting up the screen which usually means something is running....
    05-12-2017 05:22 AM
  3. LineKill's Avatar
    It is a limitation of Quick Charge 2.0. Quick Charge 4.0 does not have this limitation and also provides a faster charge.
    Edit: Apparently it is Samsung's Adaptive Fast Charge technology, which is Samsung's version of Quick Charge 2.0, that has the limitation and not a limitation of Quick Charge 2.0. When a test was done on the ZTE Blade V8 Pro, which features a similarly sized battery and Quick Charge 2.0, it took an 1hr 32min compared to the S8 which took 2hrs 51min to charge while playing a YouTube video the entire time.
    05-12-2017 05:28 AM
  4. dejanh's Avatar
    Ha, this explains why I found the S8+ to not charge any faster than my iPhone 7 Plus, in fact sometimes slower than the iPhone. Good info and just wow Samsung. Quite a fail.
    05-12-2017 05:28 AM
  5. LineKill's Avatar
    It still displays a fast charging notification even when it is not fast charging. It takes almost twice as long to charge when the screen is on.
    05-12-2017 05:38 AM
  6. sweetypie31's Avatar
    When fast charging wasn't a thing didn't charging slow down anyway if you were using the phone?At least for me my charging always took a little longer if I used the phone while trying to charge it.
    sparkeater79 likes this.
    05-12-2017 06:48 AM
  7. sparkeater79's Avatar
    Whoops
    05-12-2017 09:48 AM
  8. sparkeater79's Avatar
    Basically yes. Maybe more so the fact that the battery was being drained at the same time it was being charged. Makes sense it would take longer to charge in this senario.
    Tim1954 likes this.
    05-12-2017 09:49 AM
  9. dejanh's Avatar
    Yeah, indeed. I guess then that in some cases it makes sense to use a high amperage charger then with the S8+ that is not QC compatible.
    05-12-2017 10:07 AM
  10. ThrottleJohnny's Avatar
    It also makes Samsung phones very warm and even hot. I don't think they wanted to fool around with that this go round.
    As a result, the S8 stays relatively cool, has great battery life which should sustain itself much longer than past phones. I don't see this as a fail...at all.
    05-12-2017 10:22 AM
  11. furiousyellow's Avatar
    Does this also apply when you have the Always On display enabled?
    05-12-2017 01:14 PM
  12. Jaycemiskel's Avatar
    Yeah, I think that's what I'm going to do in my car. There was a post in another thread on here that determined that it charged faster with the screen on with a non quick charge charger.
    No, AOD should charge at a normal quick charge rate.
    05-12-2017 04:03 PM
  13. sweetypie31's Avatar
    My original statement was kind of in reference to the person who said it was a fail on Samsung's part. This situation isn't new in phones so how is it a fail?
    05-12-2017 08:14 PM
  1. Battery drain on my meizu m3 note
    By Luca97 in forum Ask a Question
    Last Post: 06-02-2017, 09:51 AM
  2. Whats the next part for the below post?????????
    By juvenilah in forum Ask a Question
    Last Post: 05-15-2017, 08:53 AM
  3. A question on sound quality
    By BowtomePhil in forum LG G6
    Last Post: 05-15-2017, 06:54 AM
  4. Replies: 0
    Last Post: 05-12-2017, 04:18 AM
  5. S6 Edge not booting up after Android 7 Nougat
    Last Post: 05-12-2017, 03:32 AM
