1. AC Question's Avatar
    I recently upgraded from the S5 to the S8+. Other than the usual quirks of learning how the new interfaces work, I am having an issue with text messaging via bluetooth to my car.
    So I have the Samsung S8+, and I have it paired with my '14 Honda Accord via the Hands Free Link. I can get phone calls, Pandora, and other bluetooth services to work just fine, however the system will no longer notify and read me text messages. I check the bluetooth settings and Call audio, Media audio, Contact Access, and Message access are all turned on.
    The S5 worked just fine in that regard.
    Options, settings, workaround?
    05-12-2017 09:59 AM
  2. erasat's Avatar
    I set mine the first day just like any other phone I had before and it worked just the same, then yesterday morning I realized that my Messages were not been received on the car and after a couple of tests I realized that something was not right, so I just unpaired the connection on the phone and delete the car's connection, I paired them again, gave permissions to read contacts and messages when they were asked for and at first it didn't work but then I remembered that my previous iPhones (all the Androids have been fine) needed to restart the Car's system after pairing it for the SMS to work, so I did that and it began working again.
    It seems to have been a glitch somewhere, try the same to see if it helps.
    05-12-2017 11:31 AM
  3. m3lover1's Avatar
    Opposite for me. Previous couple phones messages either never synced properly with my car, or is super delayed in receiving them. I would get a text and it wouldn't show up on my car until 15 to 20 min later. With the s8+ it shows up within 1 to 2 min after receiving it.
    2017 Subaru STI
    05-12-2017 11:39 AM
  4. k3m1c6's Avatar
    My S8+ has not had an issue with receiving or reading texts though Bluetooth since day one.
    2014 Kia Forte
    05-12-2017 12:02 PM
  5. TabGuy's Avatar
    Ironically I've never received messages on my 2009 Edge. Imagine my surprise when text messages started showing up.
    05-12-2017 01:56 PM
  1. Replies: 1
    Last Post: 05-30-2017, 06:18 PM
  2. No sim kit charge anymore?
    By wessock in forum General Carrier Discussion
    Last Post: 05-14-2017, 08:36 PM
  3. hiding app shortcut from launcher in android 4.4
    Last Post: 05-12-2017, 01:29 PM
  4. Using phone as video player via USB to chromebook
    Last Post: 05-12-2017, 01:28 PM
  5. Why am i unable to make video calls?
    By malek yahyaoui in forum Samsung Galaxy S6
    Last Post: 05-12-2017, 09:58 AM
