1. Keith Molloy's Avatar
    Anyone? Its bugging me that i cant adjust the individual sound modes! I do not want my 'normal' sound mode to use vibrate so i turn vibrate off but this also turns it off for vibrate mode so when i enable vibrate mode its basically silent with no vibrate! Anyway to get vibrate mode to actually vibrate without vibrate being enabled for normal mode aswell
    05-13-2017 10:07 AM
  2. kevinpleasants's Avatar
    Try Simple Sound Profile in the play store. It's a widget that you can customize your sound.
    05-13-2017 10:09 AM
  3. Keith Molloy's Avatar
    I should be able to do so from stock though! I usually turn off vibrations for 'normal' mode so my phone just rings without vibration and if i want vibration then i toggle vibration mode on but on the S8 once you adjust vibration its like that for all sound profiles so iam unable to put my phone on silent but still have it vibrate
    05-13-2017 10:17 AM
  4. anon(238680)'s Avatar
    The manual does not list "sound profile" but for Sound Mode it appears you should be able to do what you want. Manual not real clear in detail, but it appears everything is in Settings/Sounds and Vibration/Sound Mode. Don't know if that helps at all...
    05-13-2017 11:56 AM
  5. Keith Molloy's Avatar
    Not really mate. Basically we have 3 sound modes (normal, vibrate and silent) but if i go into my sound and vibration settings and lets say i turn vibration off....... it turns vibration off for all 3 sound modes so whichever sound mode i use, there will be no vibration! This is not how i want it! I want to be able to adjust each sound mode individually
    05-13-2017 01:36 PM
  6. anon(238680)'s Avatar
    Not really mate.
    Sorry, but as noted above, looks like a 3rd party app is the answer.
    05-13-2017 01:50 PM
  7. Keith Molloy's Avatar
    Can anyone actually just turn vibrate off for there normal sound mode and then toggle on vibrate mode and confirm if the phone vibrataes or not because i cant understand this! Every phone EVER would allow me to toggle vibrate to off under one sound mode and still vibrate under another! Seems very odd
    05-15-2017 07:10 PM
  1. It is possible to use multiple joysticks on Android device?
    By ThomasKK in forum The Gamer's Lounge
    Last Post: 06-06-2017, 12:01 PM
  2. Find My Mobile Not Working / How To Access Cloud From Win 7 PC / Cloud Backup
    By Robert Lindsay in forum Samsung Galaxy S7 edge
    Last Post: 05-17-2017, 03:52 PM
  3. how to add speed dials on android 51 lollipop
    By j stubbs in forum General Help and How To
    Last Post: 05-13-2017, 10:27 AM
  4. Replies: 0
    Last Post: 05-13-2017, 07:42 AM
  5. How to support NFC in android emulator?
    Last Post: 05-13-2017, 07:26 AM
