1. kalinakara's Avatar
    Coming from Google Pixel, where the battery was part of the top swipe down control panel (where I can pull it down, press and hold and go right into the detailed battery stats), I feel a bit lost.
    How do you guys access your battery stats now? Is there a quick way to do it or do I have to go into the device maintenance section to get to it?
    05-13-2017 11:45 AM
  2. vasekvi's Avatar
    Make a shortcut to your launcher
    05-13-2017 11:51 AM
  3. erasat's Avatar
    The main reason why I didn't switch this time from Nova is because even when the Default UI is quite good and beautiful, there are still things missing that I'm too used to, this being one of them and gestures. To make things worse now we don't have the option to create a Shortcut widget to Settings like we had before, with that you could easily create a Settings shortcut and then look for the Battery stats and create it.
    What you are looking for comes with Android 7.1, so if you want to keep using Samsung Experience (Touchwiz) UI you won't have this until 7.1 update, in the meantime you can do what I did, just make Nova to look like the Touchwiz UI even the Weather Widget and then you will have the best of both worlds. Nova has this incorporated, just create a shortcut to the Settings on your desktop and then just ng press on it and you will have what you are looking for.
    05-13-2017 12:35 PM
  4. LineKill's Avatar
    Another option is to install Shortcutter Quick Settings. It will allow you to add a quick settings battery button. You just swipe down and tap on it and it will take you directly to your battery stats.
    https://play.google.com/store/apps/d...id.shortcutter
    05-13-2017 01:48 PM
  5. Keith Molloy's Avatar
    If your using Nova , you can long press the homescreen, widget and select nova activities which lets you choose an endless amount of shortcuts! Its great! I created 5/6 shortcuts that i use regularly and placed them in a folder named shortcuts which i have in my dock! A quick swipe up on the folder icon brings me to my app drawer!
    05-13-2017 02:00 PM
  6. kalinakara's Avatar
    Cool, all good suggestions guys. Thank you. Main reason for the post was to make sure I'm not missing an obvious solution and sounds like I'm not.
    LineKill likes this.
    05-13-2017 02:31 PM
  7. frellingfrakker's Avatar
    Long press on the Power Saving icon in the notification shade will take you to the battery.
    justafew and Twodawgzy2015 like this.
    05-13-2017 02:36 PM
  8. kalinakara's Avatar
    Exactly what I was hoping for, sir! Thank you so much!
    05-13-2017 02:44 PM
  9. justafew's Avatar
    Another way is using the Edge Panels and add the option for Device Maintenance. The very top one is for Battery. So then you swipe to open the Edge Panel and click on the Battery. Not quite as quick as the Power Saving icon referenced by frellingfrakker if you have multiple panels (i.e. contacts, weather, etc).
    05-14-2017 11:59 AM
  1. Replies: 2
    Last Post: 05-24-2017, 01:27 AM
  2. Change bubbles to bold letters
    Last Post: 05-13-2017, 11:18 AM
  3. Replies: 0
    Last Post: 05-13-2017, 11:05 AM
  4. Unable to permanently delete data kept on Avast servers
    Last Post: 05-13-2017, 11:01 AM
  5. Replies: 0
    Last Post: 05-13-2017, 09:38 AM
