1. srfoot's Avatar
    Twice today I tried using the FPS and it did not work, vibrate feedback, etc.
    I had to reboot the phone then it worked.
    Software glitch?
    Any fix known?
    Thank you.
    anon(9023234) likes this.
    05-18-2017 03:21 PM
  2. dpham00's Avatar
    I have never had this happen to me. Which variant do you have?
    05-18-2017 03:22 PM
  3. anon(9023234)'s Avatar
    Started happening to me a couple of weeks ago, but rarely. Now it happens multiple times a day. Might be time for an exchange.
    05-18-2017 03:43 PM
  4. blaine07's Avatar
    This has happened to me a couple times since I've had phone. Haven't found a doc or any "constants" either. 🤔
    05-18-2017 04:30 PM
  5. srfoot's Avatar
    SMG950U
    05-18-2017 04:53 PM
  6. trucksmoveamerica#AC's Avatar
    The FPS has always unlocked my phone, but the gesture feature of dropping the notification bar acts up every once in a while
    05-18-2017 08:10 PM
  7. erasat's Avatar
    If you have the fingerprint gestures on, turn it off and see if it helps. There are other people with similar issues, I've had it about three times now but in my case it has been after having the FP wet, but it seems that it may be software glitch and the only thing that seems to be related to that is the gesture.
    05-18-2017 08:35 PM
  8. anon(9023234)'s Avatar
    I'll try that and report back.
    05-18-2017 09:30 PM
  9. anon(9023234)'s Avatar
    So far so good. Disabled the fps notification function, no fps issues since and it actually appears much more responsive than ever.
    05-19-2017 11:20 AM
  10. srfoot's Avatar
    Which function did you disable and where is its location.
    Thank you.
    05-19-2017 11:37 AM
  11. Almeuit's Avatar
    I haven't run into this. I do reboot once a week though so maybe that is holding the issue off?
    05-19-2017 12:23 PM
  12. furiousyellow's Avatar
    Thank you.
    Settings/Advanced Features/Finger sensor gestures is what I believe is what he's talking about.
    05-19-2017 12:32 PM
  13. anon(9023234)'s Avatar
    That's it, thanks.
    05-19-2017 08:07 PM
  1. Why Cant i get my wifi calling to work
    Last Post: 05-22-2017, 08:59 AM
  2. S pen works for a while then becomes undetected
    Last Post: 05-18-2017, 12:42 PM
  3. how to stop it from reading apps to me
    Last Post: 05-18-2017, 12:41 PM
  4. Will this phone work with LTE on ATTWillKossssss
    Last Post: 05-18-2017, 12:29 PM
  5. auto clicker app that doesn't require root?
    By all_bran in forum Android Apps
    Last Post: 05-18-2017, 11:39 AM
