1. Ben Ciha's Avatar
    Does anyone know how to change the color for each contact in edge lighting?
    05-23-2017 03:38 PM
  2. PJRed2008's Avatar
    You can't, at least with default apps.
    Qc_Anubis likes this.
    05-23-2017 03:42 PM
  3. Mr_Spencer's Avatar
    Yea. Stock options don't allow it. The edge doesn't seem to be as customizable as it was in previous phones. I used to like assigning a color to different contacts which allowed me to know who was texting/calling even if I couldn't see or read the screen.
    05-23-2017 05:55 PM
  4. Kalvin Kerns's Avatar
    I think a better question would be how to get it to work at all...
    05-23-2017 06:11 PM
  5. digitalbreak's Avatar
    This ^^
    I would care more if this damn thing worked! Right it only works with SMS messages for me and not for any other apps.
    05-23-2017 07:45 PM
  6. coolioe93's Avatar
    It gets the color from your background wallpaper. Change your wallpaper and the edge lighting color changes as well. You can't choose a specific color afaik
    05-23-2017 08:01 PM
  7. Kalvin Kerns's Avatar
    This ^^
    Wow it works for you? Cool. Mines never worked. I'm seriously thinking of sticking with a flat screen phone next time around. The curves seen to be causing more problems (no screen protectors etc) than that are worth.
    But hey, I'm gonna enjoy this phone until it's time for a new one.
    05-23-2017 09:22 PM
  8. Mariah Richardson's Avatar
    Yep, same here, mine doesn't work at all, never has, not ONCE.
    05-24-2017 06:26 PM
  9. Novaprime's Avatar
    I know this is possibly a silly question from me, but have you guys chosen which apps you want to work with edge lighting? Mine works only for the apps I chose. Saying that, I totally believe that some people could have an issue where it doesn't work.
    06-28-2017 03:17 AM
  10. bassplayrguy's Avatar
    I don't have any issues with mine that I'm aware of. It works.
    06-28-2017 09:13 AM
  11. Seiyonblem's Avatar
    You should change your settings of edge lightning in quick setting panel. You can add more apps for the notifications
    06-30-2017 03:23 AM
  12. Topher Doucet's Avatar
    Mine won't even turn off?! It wasn't even working the first week now on week 2 and the right side of my screen is stuck with a pinkish edge light all down the side. Even did a factory reset with no luck. Think I've got a dud...fml
    08-24-2017 02:38 AM
  13. CharlesWinston's Avatar
    I just learned it now after reading your comments.. Its automatically changing depends on the Album Art Color.. The picture of your music..
    Samsung Galaxy s8
    10-14-2017 07:53 AM
  14. CharlesWinston's Avatar
    Samsung Galaxy s8
    10-14-2017 07:53 AM
  15. CharlesWinston's Avatar
    Lol..wrong section 😂
    10-14-2017 07:59 AM
  1. Full screen on Fb messenger
    By tobrizonwireless in forum Samsung Galaxy S8 & S8+
    Last Post: 02-12-2018, 02:51 PM
  2. S8 in silver in uk?
    By AC Question in forum Samsung Galaxy S8 & S8+
    Last Post: 05-24-2017, 09:42 AM
  3. Replies: 1
    Last Post: 05-24-2017, 12:03 AM
  4. What built in apps are safe to remove/disable from stylo 2
    Last Post: 05-23-2017, 02:40 PM
  5. S8 in silver in uk?
    Last Post: 05-23-2017, 01:56 PM
