1. sparkeater79's Avatar
    I saw a post not long ago asking about salt water and the galaxy s8. I searched but can't find anything(I don't know why but it never finds anything I search for). I am at the beach now and have been for 4 days. I have thoroughly put my s8 through the ringer on the beach. I have dropped it in the ocean, in the sand, dropped in the sand and didn't realize it dropped while the water washed back and forth on it. When I found it it was almost completely buried in the sand. I grabbed it took it to the rv sink and rinsed it. It seams like everything is working fine. This is a good phone so far.
    I have a case on it 24/7 but at the beach it is going butt naked.
    06-05-2017 11:07 AM
  2. munnarg's Avatar
    Salt water can do way more damage than fresh water, so you should monitor the phone over the next few days.
    06-05-2017 11:18 AM
  3. dlalonde's Avatar
    As far as I know, the tests are made with fresh water. All other liquids can cause damage.
    jacker likes this.
    06-05-2017 11:27 AM
  4. jacker's Avatar
    Just don't make it annual occurrence, reason being is the salt WILL corrode.
    So while it's cool it held up it won't over a prolonged period of time.
    06-05-2017 11:29 AM
  5. Almeuit's Avatar
    Don't do it. Salt water is corrosive.
    06-05-2017 11:34 AM
  6. bassplayrguy's Avatar
    Did the sand scratch the glass on the front or back?
    06-05-2017 01:52 PM
  7. Jaycemiskel's Avatar
    That was my concern. I definitely won't be trying this. Glad to know it held up to the saltwater though.
    06-05-2017 03:46 PM
  8. Kalvin Kerns's Avatar
    Wow, you're brave to go naked at the beach.
    06-05-2017 04:22 PM
  9. novice's Avatar
    No salt water. The only caveat they gave me when I purchased the phone.
    06-05-2017 08:59 PM
  10. Gary02468's Avatar
    If you read the User Manual, you'll see that (1) the phone is not rated for exposure to salt water, and (2) if your phone is exposed to salt water, you're supposed to rinse it with fresh water immediately. "Failure to rinse the device in fresh water and dry it as instructed may cause the device to suffer from operability or cosmetic issues."
    06-06-2017 07:33 AM
  11. sparkeater79's Avatar
    Already did it. Not on purpose.
    I had to blow out the ports real well but after that it charged to 100%twice without issues and I have NOT noticed anything wrong.
    No scratches on the front or back from sand. That is why I went naked. If I had left it the case it would most definitely have gotten scratched all over. I do pay for the insurance for damage or loss protection, and the damage does include water damage.
    I did also rinse the phone as soon as it saw sand each time.
    I have left the beach and am back at work and the phone seems the same as before. Not one symptom. This thing is built well. No doubt.
    06-06-2017 09:11 AM
  12. Aquila's Avatar
    Both sand and salt water are terrible ideas. It's not rated to withstand either.
    06-06-2017 04:08 PM
  13. bassplayrguy's Avatar
    I'm glad you were able to throw caution to the wind and enjoy your phone. I am not that brave lol.
    sparkeater79 likes this.
    06-06-2017 05:56 PM
  14. Ev C's Avatar
    Yeah iP68 ratings are not salt water ratings. The fact that you rinsed it with fresh water immediately is good.
    sparkeater79 and jbjtkbw007 like this.
    06-06-2017 09:07 PM
  15. sparkeater79's Avatar
    I showered it real well last night. I know direct water stream to the ports or seals is not good but again the phone is working properly.
    There are a few things I don't like about the galaxy s8 but build quality is NOT one of them. Best built Samsung I have ever used.
    06-07-2017 07:20 AM
  16. jeetu4444's Avatar
    i took my G6 in the sea...and after the swim...(it was in a case...) i did some shopping and sheesha...after 2 hrs when i was back in the room i rinsed my phone under tap water and phone was working fine after 1 day after charging port was dry (rinsed the phone naked )
    06-07-2017 09:52 AM
  1. How do you update LG G5 core apps?
    By AC Question in forum LG G5
    Last Post: 07-04-2017, 03:28 PM
  2. My Samsung A5 2016's fast charging feature is not working
    By XVI Top in forum Samsung Galaxy A5
    Last Post: 06-06-2017, 12:17 PM
  3. alternative password forget to reset galaxy S5 device
    Last Post: 06-05-2017, 01:33 PM
  4. Replies: 2
    Last Post: 06-05-2017, 01:08 PM
  5. How do I make Wear notifications last longer?
    By ruhban in forum Ask a Question
    Last Post: 06-05-2017, 11:38 AM
