1. AC Question's Avatar
    I forgot the pin on my S8+ and the instructions for a hard reset require a power off but phone requires pin to power off. Any suggestions on either recovering pin or getting around this catch 22 for power off and subsequent reset?
    06-17-2017 08:30 AM
  2. belodion's Avatar
    It isn't really a Catch 22-type thing, but a security method that assumes that the user will go to the trouble of making a note of such an important thing as a PIN or password.
    You may be able to reset the PIN via Android Device Manager or any other device manager app you may be using.
    H3aTeRzz likes this.
    06-17-2017 08:55 AM
  3. jlangner's Avatar
    If it was easy then someone's stolen phone could easily be reset
    06-17-2017 08:59 AM
  4. Wbutchart1's Avatar
    Trying going to Google my devices. Use their option to reset device. I had to do that once after putting in a pattern and forgetting it immediately...might have been beer related....
    06-17-2017 09:34 AM
  5. gregg6942's Avatar
    LOL
    Qc_Anubis likes this.
    06-18-2017 03:47 PM
  6. TheyCallMeBT's Avatar
    Interesting, I didn't know this. Seems like there would be some (physical) safety concerns with this. Like if the phone was so hot that it was a hazard and a stranger found it like that or the touch screen wasn't working, that you could turn it off. I don't miss the removeable batteries so much any more, but it was a piece of mind that if it was messing up, you could just pop the battery out.
    06-18-2017 04:58 PM
  7. Lepa79's Avatar
    Learn a good lesson the hard way? Please don't drink and set PINs, Patterns, or Passwords. Finger prints, IRIS, and face recognitions are OK. Just make sure they are yours.
    Joking aside, your solution should work . Did you figure that out the day after your 🍻? lol
    TheyCallMeBT likes this.
    06-18-2017 06:02 PM
  8. Wbutchart1's Avatar
    Joking aside, your solution should work . Did you figure that out the day after your ? lol
    It did work... In the end, took a few times using Google my devices before it took place and reset the phone.
    Realised pretty quick, changed it to pattern and then couldn't get in! Never used pattern since... Sober or otherwise ☺️
    06-18-2017 06:15 PM
  9. jeffmd's Avatar
    Or you could just put in the wrong code 10 times and it will reset the phone.
    ScottsoNJ likes this.
    06-18-2017 08:12 PM
  1. S8+ Facebook camera photo roll
    By AC Question in forum Samsung Galaxy S8 & S8+
    Last Post: 06-19-2017, 10:57 AM
  2. Replies: 1
    Last Post: 06-17-2017, 07:12 PM
  3. Where is backup pin entry?
    Last Post: 06-17-2017, 07:09 PM
  4. At 2017 won't automatically connect to parrot 3100 car kit
    Last Post: 06-17-2017, 08:58 AM
  5. S8+ Facebook camera photo roll
    Last Post: 06-17-2017, 06:05 AM
