1. AC Question's Avatar
    I want to disable the MMS conversion from SMS once I reached the max of 160 characters in S8+. How do I do that? Tried to check messages settings but can't find solution. Before I could text long messages as SMS without it converting to MMS. Very frustrating.
    06-18-2017 11:10 AM
  2. TheyCallMeBT's Avatar
    I don't use the stock app, so I'll leave it to someone else to answer if it can do it. But if you're open to other apps for SMS/ MMS, Textra is a great app and it has this option.
    06-18-2017 05:10 PM
  3. TheyCallMeBT's Avatar
    Screenshot
    Attached Thumbnails MMS conversion from SMS and how to stop it in S8+-screenshot_20170618-171001.jpg
    06-18-2017 05:12 PM
  4. sangs's Avatar
    Can I just ask why you want to do this? Doesn't that make the person on the other end confused when it starts splitting up SMS texts in the incorrect order?
    06-19-2017 09:38 AM
  5. SlippySlimm's Avatar
    I'm curious about this myself. What's the benefit of turning this option off?
    06-19-2017 12:00 PM
  1. Default message app is not visible in Android Lollipop 5.1
    Last Post: 06-20-2017, 04:32 PM
  2. Replies: 1
  3. How to unblock a number in my Galaxy J7
    Last Post: 06-20-2017, 04:28 PM
  4. How do i get to the songs on my sd card?
    Last Post: 06-20-2017, 04:25 PM
  5. S8+ to G6 - 24 hours in
    By neil74 in forum LG G6
    Last Post: 06-18-2017, 09:18 PM
