Hello, I was using my samsung galaxy 8 with few apps and after setting it up to no wifi and taking pictures after that the bar if notification was not working.
I saw other people complaining with the same issue and some have talked to go in safe mode and change user but I don't see that option in the Samsung 8.
I had to install an app that create a short cut to bring down the notification
Anyone have a solution ?
Thanks
Thanks
