1. Squidugala's Avatar
    I have a S8+. I downloaded Samsung music but It can't find my music.
    06-23-2017 06:44 PM
  2. erasat's Avatar
    It should ask you for permissions, did you give it full permissions? Try going to Settings-applications and look for the app and then go to permissions. If still the same, try going to the same menu but go to Storage and clear cache and data and it should reset and ask you again next time you open it.
    06-23-2017 06:54 PM
  3. Squidugala's Avatar
    Didn't work, music still can't see any music.
    06-23-2017 09:51 PM
  4. Squidugala's Avatar
    Ok, totally given up on Samsung music for now, anybody got and suggestions on how to get all my music to play at the same volume?
    06-23-2017 10:24 PM
  5. Qc_Anubis's Avatar
    Look in the Eq/sound settings you should find something to help you.
    06-23-2017 10:56 PM
  6. Squidugala's Avatar
    Not in Google play music. At least none that I've found.
    Qc_Anubis likes this.
    06-24-2017 12:34 AM
  7. swagglepuff's Avatar
    In Samsung music there is a smart volume toggle in the settings.
    06-25-2017 11:58 AM
  8. Squidugala's Avatar
    Yes but unfortunately I never got music to work.
    06-26-2017 07:44 AM
  9. swagglepuff's Avatar
    That's so weird, there are a bunch of third party players that have this option available as well.
    06-26-2017 06:10 PM
  10. Squidugala's Avatar
    Any specific apps you can think of would be helpful.
    06-28-2017 11:51 PM
  11. swagglepuff's Avatar
    The one that comes to mind is power amp. its one of the better ones out there as well. If you feel like it call or chat with Samsung, they have vastly improved customer service lately.
    06-29-2017 12:56 PM
  12. BratPAQ's Avatar
    It's called volume normalization. Try Mp3gain but it's for desktop.
    https://sourceforge.net/projects/mp3gain/files/
    You feed all your music files to this application before transferring it to your phone. It writes the needed replay gain to your music files to make all the volume equal. Then copy the files to your phone and use music app like poweramp. And in settings turn on replay gain.
    https://play.google.com/store/apps/d...pz.audioplayer
    06-29-2017 02:33 PM
  13. BratPAQ's Avatar
    Try placing your music on download folder. Then on Samsung music app browse to it via folder.
    06-29-2017 02:40 PM
  14. Wickerman1972's Avatar
    I've been trying to find a solution to this as well. As mentioned above the Samsung player has this feature but it doesn't work well imo. The problem with it is that it appears to look at only the very start of a song. So if a song starts out very loud it will turn it down but if a song begins quietly but gets loud later it cranks it up and never makes another adjustment to it. Last I tried it was listening on random and it turned down an Amon Amarth song after the first few notes. The next track was by Iron Maiden and that started softly with clean guitar so the Samsung player turned it up. When the heavy part kicked in it was at an earsplitting level and stayed that way until the next song loaded. This really doesn't cut it.
    02-06-2018 06:28 AM
  1. Factory reset own't help deleting the virus
    Last Post: 09-02-2017, 12:12 PM
  2. How to stop annoying low battery reminders?
    By garybeckvt in forum Android 6.0 Marshmallow
    Last Post: 06-23-2017, 10:05 PM
  3. Replies: 1
    Last Post: 06-23-2017, 07:14 PM
  4. Replies: 0
    Last Post: 06-23-2017, 06:32 PM
  5. How do I delete a game from my Google Play Games account?
    Last Post: 06-23-2017, 06:08 PM
