1. rdburke's Avatar
    Just got the Samsung Galaxy S8+........Really like the slo-mo feature on the camera but is there not a way to shoot a full length video in slo-mo? As far as I can tell there are only two spots in the the footage you take that you can get slo-mo. What good is that? If there is not a way to remedy this, is there any other camera app I can get that will perform the way I want it to? Thanks in advance!
    06-26-2017 10:05 AM
  2. uncreativeartist's Avatar
    I only used the slo-mo function when I was first messing around with the camera. You can edit the video to set the slo-mo section/s you want and if you want to you can make the full video slo-mo. It's in the editing after you take the video.
    06-26-2017 01:48 PM
  1. How can i hide time on samsung j5 home screen
    Last Post: 06-26-2017, 11:59 AM
  2. Replies: 1
    Last Post: 06-26-2017, 11:53 AM
  3. Replies: 1
    Last Post: 06-26-2017, 11:52 AM
  4. Does FOXFI work on latest version upgrade for note 5?
    By DonnaGA in forum Ask a Question
    Last Post: 06-26-2017, 08:27 AM
  5. Replies: 1
    Last Post: 06-26-2017, 07:34 AM
