1. eric002's Avatar
    https://news.samsung.com/global/tips...laxy-s8-and-s8
    I don't know about everyone here, but for the most part, I disabled the edge screen and use the palm swipe feature to take a screenshot, and the swipe up and down to across my app folders. 2jat about everyone else when?
    For example, all of mY info is the Google app obviously...
    06-27-2017 07:39 PM
  2. PJRed2008's Avatar
    Not sure where you're going? I also use palm swipe, but also use Edge a lot, very handy IMO. I prefer screens so only use up/down if I need and app I don't use often, as those are on my home screens.
    06-27-2017 07:45 PM
  3. eric002's Avatar
    Ok i can understand that. I have my app folders in my swipe up and down i and haven't found much other use for the edge panels otherwise. What other edge panels do you use though?
    06-27-2017 07:49 PM
  4. sweetypie31's Avatar
    I use the edge screen and palm swipe. I initially Didn't think I'd find the edge screen useful, but it's been very useful. I did try to use the task edge where you can press the button to screen cap, but I didn't like it.
    06-27-2017 07:50 PM
  5. eric002's Avatar
    Yeah I u tried that, and the samsung internet bookmarks panel, but I honestly could get used to it... Unfortunately.
    06-27-2017 07:52 PM
  6. PJRed2008's Avatar
    I have Apps, people, Data usage, and quick tools. Have tried others but usually forget them or don't use them. I much prefer Apps on the Edge.
    ticketbabe2 likes this.
    06-27-2017 07:58 PM
  7. eric002's Avatar
    Mmm gotcha. I'm getting much more used to the folder apps by the swipe up and down now. For my weather, it's through the Google App etc. Just wanted to get everyone else's suggestion as to what you use the edge for. Thanks for the responses so far!
    06-27-2017 08:00 PM
  8. msp1518's Avatar
    I'm flying from china to NC right now and an S8 is waiting for me. I have NO IDEA how to use it, android and the side swipe thing. As an Apple guy for years I am going in blind. Heaven help me!!
    06-27-2017 08:18 PM
  9. eric002's Avatar
    Oh belive me, you'll love it!
    06-27-2017 08:55 PM
  10. PJRed2008's Avatar
    Heaven help me!!
    There are some very good threads here in the S8 forum for iOS to S8 converts. Might read those over while flying
    eric002 likes this.
    06-27-2017 09:00 PM
  11. Doug Moffat's Avatar
    The Edge Panel is my favorite Samsung innovation. I'm addicted. In danger of buying so many panels that it takes 10 minutes to scroll through them all. (That's hyperbole.)
    Particularly partial to apps, contact and reminder panels. Much prefer to swipe than hunt through apps on my home screen.
    Viva, Samsung!
    GRUNT11B likes this.
    06-27-2017 09:05 PM
  12. eric002's Avatar
    Haha very good point. I first I had the weather Edge, act Edge, and the Samsung internet browser bookmarks Edge. But I slowly just got rid of them mostly because from my weather like I said I use the Google Weather app and the updates from Google Search application, and for my apps I use the apps folders by swiping up and down, and last night I have everything organized just right. On my phone so that I can find things quickly...
    06-27-2017 09:08 PM
  13. PJRed2008's Avatar
    And now you did it, I sense a reset in your future
    eric002 likes this.
    06-27-2017 09:21 PM
  14. sweetypie31's Avatar
    The edge panel really helps me to not have all my frequently used apps on my home screen screen. I didn't realize I had so many apps crammed into a folder on my home screen until I crammed them all on the edge panel. Lol
    PJRed2008 likes this.
    06-28-2017 05:45 AM
  15. BratPAQ's Avatar
    I believe smart select can only be found in edge panel.
    06-28-2017 06:54 AM
  16. eric002's Avatar
    06-28-2017 07:26 AM
  17. eric002's Avatar
    I gotcha. See, for me, at first I had all my app folders in my app Edge panel and I wasn't swiping up and down on the home screen but I would accidentally swipe up and down and the apps would still be there in a miscellaneous folder. So basically I got sick and tired of that and did away with the edge panel the other day and just organize the application folders and the swipe up and down on the home screen which is working out a little bit better since I can quickly uninstall them or find out more info about them straight from that screen as well. As far as the smart select screen the Palm capture will work well enough for me only because for the other features of the screen capture Edge panel, and never really needs them. The GIF option I never really used it was nice to be selected for the screen capture but I don't really need it so I can only download Andrea Nable it if I need it but the Palm capture for now will work fine but thanks for your suggestion and your input for your phone.
    06-28-2017 07:28 AM
  1. Galaxy S7 Edge screen destroyed by a 2cm drop
    By pixel girl in forum Samsung Galaxy S7 edge
    Last Post: 11-23-2017, 01:09 PM
  2. Downloading Photos from Yahoo Email to Samsung Galexy Edge 7
    Last Post: 06-27-2017, 02:40 PM
  3. S7 edge red LED flashlight
    Last Post: 06-26-2017, 11:04 PM
  4. Replies: 0
    Last Post: 06-26-2017, 09:13 PM
  5. Replies: 1
    Last Post: 06-26-2017, 12:08 PM
