1. AC Question's Avatar
    I receive good morning notifications from bixby at 10 pm and night notifications at around 11 am. It isn't a huge issue but it's pissing me off. Is there any way ro change the timezone bixby uses? Is it tied to my samsung account? If yes, then can I change the account's timezone? My phone is a galaxy s8+.
    Ps: don't tell me how bixby is bad and how I should disable it. I just want my issue solved. Thanks.
    06-28-2017 04:09 AM
  2. anon(238680)'s Avatar
    Welcome to the forums. Bixby uses the timezone set on the phone, there is no timezone associate with the Samsung account. Are you sure you have the notifications for wakeup, etc, set correctly?
    If you need additional help or have more questions or details to share, please join the site so you can reply in this thread. See this link for instructions on how to join Android Central.
    06-28-2017 08:06 AM
  1. Replies: 12
    Last Post: 07-07-2017, 12:49 AM
  2. How to detect interrupt line number corresponding to touch sensor on any Android phone?
    By AC Question in forum Software Development and Hacking
    Last Post: 06-28-2017, 11:28 PM
  3. Is this a question and answer application?
    Last Post: 06-28-2017, 04:52 AM
  4. Replies: 0
    Last Post: 06-28-2017, 04:06 AM
  5. What else can I do
    By awomojure in forum Samsung Galaxy S2
    Last Post: 06-28-2017, 03:26 AM
