07-04-2017 11:04 PM
36 12
tools
  1. pankaj981's Avatar
    Okay so you must have bought yours out right
    That's right, I always buy my phones outright.
    jettie1767 likes this.
    07-01-2017 07:52 AM
  2. edubb256's Avatar
    If the screen is too big for you to operate comfortably in one hand, have you tried one-handed mode? I don't use it very often, but it does come in handy from time to time. https://uploads.tapatalk-cdn.com/201...f3cf2e18a3.jpg
    Also, one-handed mode activated this way (with a swipe) works better if you keep your finger on the screen after you swipe up and then swipe down slightly to resize...all in one motion.
    Lepa79 likes this.
    07-02-2017 10:19 PM
  3. pankaj981's Avatar
    I got the S8 Plus today and the in hand feeling is more or less the same as the S7E, though it's slightly taller. The FPS reachability is still a mess (I didn't like the S8 either) when compared to the S7E. The only reason this will stay if it satisfies the reason I upgraded... better battery life. Time will tell...
    07-03-2017 11:02 PM
  4. arunma's Avatar
    I tried out the S8 in a T-Mobile store. Coming from the S7 Edge, the S8 was just too small. Yes, I have to rely on the iris scanner a bit more, but it seems just as secure (if not more so) and is quite convenient, so it's a small price to pay for the added screen real estate.
    07-04-2017 12:26 AM
  5. Blues Fan's Avatar
    S8 Plus all the way. I had the S7 edge and regular S7. All too small for me. I like the plus size. The Note 7 was perfect though. I wouldn't have an S8 Plus right now if the Note 7 wasn't recalled. I'd be waiting for the Note 8 but the s7 edge small screen was driving me crazy and the V20 wasn't AMOLED.
    amyf27 and JHStewart1023 like this.
    07-04-2017 12:38 AM
  6. Lepa79's Avatar
    Wow, I had no idea about the resize. Holly Cats! Thank you!
    07-04-2017 06:54 AM
  7. amyf27's Avatar
    7edge was way too small to me too. Loved the V20 my main oroblem with that one was more that it didn't have Samsung Pay.
    07-04-2017 07:07 AM
  8. JHStewart1023's Avatar
    I was the opposite I got the s8... said NOPE I need battery power and went with the s8 plus and I haven't looked back... such and amazing device.
    07-04-2017 08:22 AM
  9. msp1518's Avatar
    I've gone from the iPhone 6S+ to the S8 and the only issue I am having is adapting to texting. I am failing. Completely. That very wide iPhone screen made texting vertically a snap. Not so with the S8. The keys are just too narrow so I am really struggling.
    Everything else is great. But I need to come with with a solution to this conundrum.
    07-04-2017 08:46 AM
  10. Lepa79's Avatar
    I would have tried other phones had it not been for Samsung Pay. I'm hooked!
    amyf27 and pankaj981 like this.
    07-04-2017 09:09 AM
  11. sulla1965's Avatar
    I went from s8 to the s8+, bigger screen and bigger battery. The curves are a bit less and you have more flat screen than on the s8. Erica Griffin in her review actually preferred the s8+ even with her small hands
    JHStewart1023 likes this.
    07-04-2017 11:04 PM
36 12
  1. Smart watch for S8+
    By cardboard60 in forum Samsung Gear Live
    Last Post: 07-01-2017, 03:36 PM
  2. Replies: 1
    Last Post: 06-28-2017, 10:58 PM
  3. Replies: 2
    Last Post: 06-28-2017, 10:29 PM
  4. Replies: 1
    Last Post: 06-28-2017, 09:15 PM
  5. Unable to sign in to account @me.com
    Last Post: 06-28-2017, 06:20 PM
