1. punisherdude06's Avatar
    Just upgraded from s7 edge you s8 plus. For they life of me I can not figure out how to put audio player controls in the notification bar.
    When I listen to google play or pocket casts the controls would appear in notification. So I could swipe down from any screen, even lock screen, to pause music.
    Search first 4 pages of s8 forum and couldn't find any help.
    Thanks.
    06-30-2017 11:25 AM
  2. Deke218's Avatar
    Do you have the notifications for the apps on?
    06-30-2017 11:32 AM
  3. PJRed2008's Avatar
    Welcome to the forums as a new member! It sounds like you're looking for a widget, you will not get app player controls in the dropdown notification bar AFAIK. You can set widgets to do what you've described. There is an audio control in the dropdown, you have to double pull to see it, but doesn't sound like what you're looking for.
    06-30-2017 11:35 AM
  4. BratPAQ's Avatar
    Yes you can, this is using Google play music.
    06-30-2017 11:52 AM
  5. PJRed2008's Avatar
    Thanks for the clarification. Are you on an S8? If so, can you help the OP with how you got the dropdown to work?
    06-30-2017 11:59 AM
  6. punisherdude06's Avatar
    I'm an *****. I somehow turned them off after turning them on. Had to reset the apps and then they came up. Appreciate your quick response. Apologize for my brain fart.
    06-30-2017 11:59 AM
  7. paridge's Avatar
    I think this setting is in Google Home, the Chromecast app.
    06-30-2017 04:12 PM
  8. njdan30's Avatar
    Glad you got it figured was gonna say every music app ive used had it. I mainly use Amazon lately
    07-01-2017 06:17 PM
  1. Replies: 3
    Last Post: 10-09-2017, 05:28 PM
  2. Music app volume keeps goin down for the last 2 days
    By Krystal Andujar in forum Ask a Question
    Last Post: 07-03-2017, 09:12 PM
  3. No audio through aux in car with Samsung Galaxy Mega 2?
    Last Post: 06-30-2017, 11:40 AM
  4. Replies: 1
    Last Post: 06-30-2017, 08:00 AM
  5. I dropped my phone and it restarted. Why?
    Last Post: 06-29-2017, 07:07 PM
