1. AC Question's Avatar
    I found this forum when I Googled "Samsung S8 bad phone reception" and saw so many different suggestions but none of them worked for me.
    I just got my Samsung S8 this week and for the first 5 days, I had such bad reception and so many dropped calls I was convinced I got a defective phone.
    The GOOD NEWS is I found the true fix at a local Verizon wireless store yesterday and my phone is working perfectly now. So I wanted to pass it on to those of you still having trouble.
    THE FIX: (this is what they did in the Verizon store that fixed mine)
    Go to Settings-Mobile Networks-Network Mode and select "LTE/CDMA" as your preferred network (do not select "Global" which is the factory setting that appears to be causing all the problems). There is a 3rd option but the Verizon associate told me that LTE/CDMA is the best one to choose.
    As soon as he switched mine to that LTE/CDMA network the phone works great and I can still use Advance Calling HD modes which allow you to access email and view SMS texts etc. Turning off Advance Calling options eliminates the ability to do this and doesn't really effect the quality of phone reception...
    FYI (according to the Verizon guy) if you buy your phone in a store, they usually switch it to this network while you are in the store with them before they give you the phone to take home. I received mine in the mail from my company so I had no idea this needed to be done.
    I hope this is helpful to all of you still having reception issues!
    07-01-2017 10:57 AM
  2. anon(238680)'s Avatar
    Thank you for posting the detailed information about that fix. Please consider joining the forum and helping others
    If you need additional help or have more questions or details to share, please join the site so you can reply in this thread. See this link for instructions on how to join Android Central.
    07-01-2017 11:01 AM
  3. Javier P's Avatar
    Moved to the S8 forum for better visibility.
    07-01-2017 11:10 AM
  4. Doug Moffat's Avatar
    Haven't had problems with dropped calls but I took your suggestion anyway.
    07-01-2017 12:32 PM
  5. DamianP's Avatar
    Is this a verizon only issue? I have an unlocked s8+ on AT&T with no issues after plugging in APN info.
    07-01-2017 12:52 PM
  6. anon(238680)'s Avatar
    Don't believe so as the choice is general to the phone.
    07-01-2017 01:05 PM
  7. anon(7901790)'s Avatar
    The 3rd setting (GSM/LTE/UMTS) will work too, but only if you are within Verizon's LTE coverage. As a side note, Verizon is steadily dismantling its 2G and 3G CDMA networks. The 2G will be gone by 2020; 3G gone by 2021.
    07-01-2017 01:37 PM
  8. DamianP's Avatar
    I don't see any of those settings on my unlocked s8+. Most of those choices are simple on off toggles except for apn and network operator.
    07-02-2017 03:10 PM
  9. CincyGuy's Avatar
    The options are based on the carrier. I'm on t-mobile and my choices are "LTE/4G/3G/2G", "4G/3G/2G" and then something else that looked worse. The LTE option is selected and I can't imagine choosing something else would give me a better signal.
    07-03-2017 09:09 AM
  10. njdan30's Avatar
    The gsm network on Verizon and sprint is for roaming in remote areas such as where I live I'm roaming on att and T-Mobile
    07-03-2017 12:27 PM
  11. Soylent_Green's Avatar
    Sprint is the same setup as Verizon mostly, I have it on LTE/CDMA mode as well I've found it works better the the default Automatic setting.
    07-03-2017 12:44 PM
  1. Replies: 10
    Last Post: 07-04-2017, 12:51 AM
  2. Samsung a5 power button loose
    Last Post: 07-02-2017, 07:03 AM
  3. Samsung S6 Edge will not charge through port?
    Last Post: 07-01-2017, 12:41 PM
  4. Replies: 1
    Last Post: 07-01-2017, 11:16 AM
  5. How to answer phone calls
    Last Post: 07-01-2017, 10:43 AM
