11B1P
Trusted Member
Your non galaxy book pc?Flow works fine on my PC and S7. Has been working fine all along.
Got it to work now, finally. I had to allow companion devices to unlock PC. I had to use the following instructions to do it:
Run > gpedit.msc then Local Computer Policy, navigate to Computer Configuration > Administrative Templates > Windows Components > Microsoft Secondary Authentication Factor and set explicitly to Enabled
I also had to uninstall the Flow app, install latest copy of version 1 first, re-pair the device with the computer, then upgrade to the latest version of the Flow app (version 2), and then re-authenticate Bluetooth again and it finally prompted me for my pin and registered the device.
This whole thing definitely needs work. You pretty much need an IT degree to figure it out. It took me nearly 3 hours from start to finish. I also have a feeling that if I tried to do this again it would not work the same way. Let's see if it stays stable for now.
Galaxy Book 10.6
We've covered this already, you and I. Of course it works on Galaxy Books. Flow is built in Galaxy Books. We know it works on those as it comes pre-installed from the factory. The issue is installing it on a standard PC.
Because you keep telling us it works on yours which serves literally zero purpose in this thread.
Well if you want to be a smarty pants about it, your first comment was regarding the Creators Update solving the issue. I just now updated to Creators Update. Flow works without CU being installed.
Hi all, I'm trying to get Samsung's new Application to work and connect on my S8 and Windows 10 Laptop. https://help.content.samsung.com/csweb/faq/searchFaq.do;jsessionid=O95HE3dO9qexZPJ4Trp4nsre.wsite21
The article says that both of my devices are compatible, the windows client won't' work at all. Has anyone else tried this at all? Thank you for any feedback.
This is why children shouldn't have internet access.
Yes Flow works without the Creative Update, ONLY on Galaxy Books. We arent talking about Galaxy Books. I really cant make that any clearer.
Hey smarta$$, I'm more than likely older than you, so get off your high horse.
This whole conversation started about Flow not working. Nothing from the get-go stated anything about Galaxy Books or non Galaxy Books. Yes, I have a GB and it came installed, so lose your attitude. It has been determined that normal pc's are having issues.
