01-03-2018 01:46 PM
41 12
tools
  1. PaulQ's Avatar
    I just spent half an hour with AT&T tech support on activating HD Voice on this new 8+. I haven't had a phone with that capability before. I know it only works with other AT&T users who have it but... that's my family.
    First, there are some weird issues with IMEI but that aside... he did things on his end, I rebooted a few times... now I am getting "LTE+" sometimes as opposed to just "LTE"
    Is "LTE+" what AT&T uses to indicate you can get HD Voice? Or other things? The guy didn't seem to be able to answer that clealry. I figured you guys would know better.
    Thanks!
    07-05-2017 12:05 AM
  2. DamianP's Avatar
    Thanks!
    Is this an ATT branded or unlocked?
    I have an unlocked S8+ and have seen the LTE and LTE+ . Since I have an unlocked, I don't get HD Voice, I assumed it was greater bandwidth per what I have read in differences of LTE and LTE+.
    07-05-2017 12:15 AM
  3. PaulQ's Avatar
    I have the unlocked version. I specifically asked the guy if that would matter. He said it shouldn't (not no). He implied that now that i have the plus, it's working.
    However, the lower tier tech support person told me to go to the CONNECTIONS > MOBILE NETWORKS > MOBILE DATA where I would find enhanced LTE settings. I don't have any. I just have a toggle for mobile data.
    Maybe if someone else reads this with AT&T, they can tell us if they have enhanced LTE settings there.
    07-05-2017 12:27 AM
  4. PaulQ's Avatar
    07-05-2017 12:28 AM
  5. JHBThree's Avatar
    I thought typically you had to have a carrier phone for those features because they're software enabled. An unlocked phone won't have the carriers software for it. That could have changed, but when I worked for ATT last year it was specifically identified that unlocked phones couldn't used advanced network features.
    07-05-2017 12:33 AM
  6. PaulQ's Avatar
    I was pretty much thinking the same thing.
    I am now questioning why I got the unlocked model. It's just a knee-jerk reaction. What is the benefit? I get all the bands?
    I was thinking why couldn't I just get the AT&T version and unlock it?
    (I'm sort of hijacking my own thread here!)
    LordGreylock likes this.
    07-05-2017 12:39 AM
  7. PaulQ's Avatar
    I do know that the unlocked model doesn't have all that AT&T bloatware!
    But this talk of delayed updates for unlocked models concerns me.
    07-05-2017 12:43 AM
  8. Almeuit's Avatar
    Try a call with it enabled and see. That's the easiest way.
    07-05-2017 12:49 AM
  9. PaulQ's Avatar
    I'm not sure I follow. With what enabled? The only option I have is data on or off. The agent told me to look for "enhanced LTE services" but I was sensing she didn't know what she was doing so I got bumped up to the next level of tech support.
    There is no indicator for HD Voice.
    07-05-2017 12:52 AM
  10. Almeuit's Avatar
    Try a call. Do you see LTE staying active ?
    07-05-2017 12:52 AM
  11. PaulQ's Avatar
    Nope. Drops to "H" and "H+" ... so what does that mean? No voice over LTE?
    This is all new to me. I thought LTE carried voice and data.
    07-05-2017 12:54 AM
  12. gernerttl's Avatar
    You should have a setting called, "Advanced Calling." Settings->Advanced Calling. This should allow you to turn on Advanced Calling if it is not already turned on.
    Otherwise, just call someone with HD Voice turned on, like Almeuit said. You'll know by the call quality of your enabled.
    07-05-2017 12:57 AM
  13. Almeuit's Avatar
    That means it's dropping back to the 3g (they call it 4g for HSPA) network. It isn't using VoLTE so chances are HD voice isn't working.
    As for what the rep said.. he is going on the AT&T branded version. Reps don't usually understand unlocked models so I really wouldn't trust what they say.
    07-05-2017 12:59 AM
  14. Almeuit's Avatar
    That's Verizon.
    07-05-2017 12:59 AM
  15. PaulQ's Avatar
    I can't find anything for "Advanced Calling"
    Is that where it is for you? SETTINGS > ADVANCED CALLING
    07-05-2017 01:03 AM
  16. Almeuit's Avatar
    It's a Verizon only thing. Only Verizon calls it advanced calling.
    As stated previously.. you don't have it from the sound of it.
    07-05-2017 01:04 AM
  17. Almeuit's Avatar
    Example of Verizon and what he is talking about.
    07-05-2017 01:05 AM
  18. PaulQ's Avatar
    Ok. My interface is entirely different. Just for the record.... here's what I have on my unlocked version:
    Is "LTE+" on AT&T an indicator of HD Voice capability?-screenshot_20170704-220748.jpg
    Is "LTE+" on AT&T an indicator of HD Voice capability?-screenshot_20170704-220754.jpg
    07-05-2017 01:11 AM
  19. Almeuit's Avatar
    Yeah you don't have it I believe. AT&T is known for not being friendly to unlocked. They want you to have their phone.
    07-05-2017 01:15 AM
  20. PaulQ's Avatar
    I am really wondering if i made the wrong choice here. I could pay a $35 restocking fee and switch to the AT&T version. I've been relatively deeply entrenched in Android for years but this carrier business is still unclear.
    Would I end up with the same freedom to use the phone anywhere if I bought the AT&T version then unlocked it with AT&T since I own it? My only concern is that I do travel internationally. I guess I would get the bloatware too. You have a lot of experience, what do you think?
    07-05-2017 01:18 AM
  21. gernerttl's Avatar
    I've been looking around and I can't seem to find anything about HD Working with an unlocked S8/8+.
    Edit: On AT&T.
    07-05-2017 01:27 AM
  22. Jnorton2724's Avatar
    I have the option for VoLTE on my unlocked S8+ using TMobile. It's under mobile networks.
    Attached Thumbnails Is "LTE+" on AT&T an indicator of HD Voice capability?-392.jpg
    07-05-2017 02:30 AM
  23. PaulQ's Avatar
    I'm going to wait until Samsung clears up my IMEI. Then, I'm going to AT&T to get a new SIM. I'll see what they have to say about this but I rarely get good techincal help in the store. Then, I'll try AT&T tech support again.
    Then... I'll give up.
    I'll come back and let you guys know what happened.
    In the meantime, anyone who is reading this with an unlocked model on AT&T, let me know if your settings are different.
    07-05-2017 02:33 AM
  24. NexusGirlX's Avatar
    I have a T-Mobile sim PLUS a AT&T sim and I tried each one in my unlocked S8+. Below are the screenshots. With T-Mobile, have the Voice over LTE option under Connections/Mobile Networks.
    Using my AT&T sim, I don't have any option whatsoever to use Voice over LTE and I do not have an Advanced calling section anywhere on my phone. I hate AT&T though because you see my reception at home is almost non existent and I do not have LTE at home so that is why I have always used T-Mobile over the last 5-6 years.
    Is "LTE+" on AT&T an indicator of HD Voice capability?-screenshot_20170705-013632.jpgIs "LTE+" on AT&T an indicator of HD Voice capability?-screenshot_20170705-012136.jpg
    Almeuit likes this.
    07-05-2017 03:44 AM
  25. PaulQ's Avatar
    Thanks for posting that. Interesting. I'll tell them that when I talk to them. I don't have high hopes.
    07-05-2017 03:47 AM
41 12
  1. What do you think of ZTE phones.
    By sdooley76 in forum Other ZTE Android Phones
    Last Post: 07-09-2017, 10:46 PM
  2. On Galaxy s8, how do I convert the app icons into a list?
    Last Post: 07-05-2017, 06:00 AM
  3. Replies: 1
    Last Post: 07-04-2017, 09:32 PM
  4. My keyboard wont show at all.
    Last Post: 07-04-2017, 08:43 PM
  5. What is the difference between the photos app and Gallery?
    Last Post: 07-04-2017, 08:40 PM
