03-06-2019 09:00 PM
44 12
tools
  1. chanchan05's Avatar
    Unfortunately, I have the same problem and cleaning the earbuds and blasting loud music from them did nothing. For the record, I used my PC jack to listen to music on them and the sound difference is still there.
    It could be actually damaged wiring.
    11-13-2017 10:55 PM
  2. kirksucks's Avatar
    Lots of similar postings on the Samsung community forums. Must be a defect. I leave my headphones sitting on my desk and use them occasionally. Only had them since Sept. and the right side is weak.
    Can I just go to Verizon and exchange them?
    11-27-2017 02:22 PM
  3. Russbuss90's Avatar
    So had this issue since step son borrowed my ear buds and thought maybe he broke a wire inside the cord. But after looking at them closely I could see a build up of something around the screen mesh on my left ear bud. So taking advice from stated above I poured hydrogen peroxide into the ear bud and it started to fizz and clean then blew in them and repoured hydrogen peroxide into the ear bud and noticed the screen mesh was coming off using tweezers I removed the mesh and now both are loud.
    So basically if you pour hydrogen peroxide in them and they fizz just remove the screen mesh. Now I gotta go talk to my step son and teach him how to clean his ears.... hope this helps.
    12-02-2017 01:08 AM
  4. Josh Spires's Avatar
    Same type of thing happens to me, but the left earphone just doesn't have any sound coming out at all.
    02-04-2018 08:27 AM
  5. smoothrunnings's Avatar
    I've bought my Samsung Galaxy S8 when it was released and it came with a pare of AKG headphones. After some time, I realised that the right earphone is much lower than the left one.
    The AKG that's ship with the S8 and S8+ are garage. Sorry I have them and my bluetooth/wired AKG headphones that I bought a costco are the best.
    02-05-2018 08:45 AM
  6. ANTONY FEROZ's Avatar
    Hi my AKG earbuds are with weired problem. Left side sound is heard in right n right in left. I tested using sound adapting in app in my note 8 and also in YouTube stereo sound Check. What should I do now to rectify this issue?
    03-08-2018 01:37 PM
  7. jeffmd's Avatar
    are you using any Eqlizer app that is supposed to help improve sound? A quick search on google is not finding any android users whose headphones has spontaneously switched sides. I can only imagine an eqlizer app that alters the audio before it gets to your headphones doing it.
    03-08-2018 07:05 PM
  8. Cosmocalypso's Avatar
    I just fixed mine actually. Ok, take off the rubber silicone covering and do a combination of blowing/sucking out air slowly in the larger hole. It may take a few minutes, but it works. I hope this helps !
    03-09-2018 10:36 AM
  9. ANTONY FEROZ's Avatar
    Hi thanks for responding. I never use third party apps for my mobile.
    03-09-2018 04:15 PM
  10. filanto's Avatar
    I don't have those headphones but I did get some other brand and it was such a terrible audio experience I almost drove back to the store. I did the adaptive sound and WOW! try it first and see what happens
    03-09-2018 04:43 PM
  11. Cosmocalypso's Avatar
    You're welcome, I hope it works for you
    03-09-2018 06:52 PM
  12. DollFaceKimmy's Avatar
    My Galaxy note 8 came with ear buds. After awhile one earbud was extremely low, to the point it sounded like no sound was coming out. Come to find out the ear bud was dirty and needed to be cleaned. Just take the rubber part off the ear bud and take some tweezer to cleans the part were the sound comes out. It has a littlle small mesh screen on it. Now I know to clean the ear buds regularly. Works like a charm
    03-12-2018 10:04 PM
  13. Soft Gaming's Avatar
    So my left earbud was so bloody quiet that I gave up took the little rubber off, and sucked on the mesh, and little did I know that I was gonna bloody get all the blasted earwax in my mouth that built up because of my ears being wet. All in all it seemed to fix my problem.
    04-25-2018 02:48 AM
  14. PauliusZZzz's Avatar
    yeah had the same issue so I just removed the mesh from the earphone cleaned it with alcohol placed it back and it's back to original volume level although I preferred the sound without the mesh
    05-06-2018 01:05 PM
  15. Seyyedhosein Akramzade's Avatar
    I was facing same problem and I have fixed it.
    You should do one thing. Open your right earphone just by pushing the red line in this pic by a sharp thing like knife = D
    http://s8.picofile.com/file/83316518...713_141025.jpg
    After opening it you should take out the round speaker (be careful. Don't disconnect wires)
    After that you should take out the shiny layer by needle showing in following pic.
    http://s9.picofile.com/file/83316518...713_140956.jpg
    Take the round silver layer and you will see a black layer stuck with that silver layer.
    That's all. Then take the object back to its place and its it's done.
    My earbuds fixed with this. Hope your earbuds fixes.
    Sorry for my bad english =))
    07-13-2018 04:49 AM
  16. Luke Carter1's Avatar
    I had the same issue but solved it take off the cushion part and then remove the screen there will be a small blackish blue thing covering the hole carefully remove that( I did this with a razor blade at work) and re-insert the screen and poof instant improvement
    Hope this helps
    So there are still no solutions?
    Yes there is I just posted a solution check the bottom of last page
    10-03-2018 04:03 PM
  17. jamesautodude's Avatar
    I had the same problem. All I had to do was remove the little mesh screen, clean, and replace it. Good as new 👍
    Dude thanks!!!! I just left the screen out cause I don't care what happens to them at this point but instantly fixed it!!!! I think it's an issue of it somehow getting clogged/plugged up, there for not allowing sound, or really even air out (in my case it would cause pressure and be hard to take out of my ear as well) of the ear bud.
    This is definitely the fix.
    01-16-2019 03:47 AM
  18. jamesautodude's Avatar
    Just leave the screen out and try it that way. Make sure nothing is down in the hole too
    01-16-2019 03:49 AM
  19. Team Chromatic's Avatar
    *SOLVED!!* yea so this might seem a bit sketchy.. it did to me but i got it back to normal volume.. if u remove the plastic part u will see a shiny gage which blocks like dust and wax on other debris from getting in there are like 2 to 3 layes which can be seperated.. just remove that and ur good to go.. just be gentle.. use like a needle or hairpin.. sumn small that can get the job done.. if its too loud u can put back one of the pieces on.. good luck
    03-06-2019 09:00 PM
44 12
  1. What happened to the Android 7.0 upgrade?
    By djdougd in forum LG V10
    Last Post: 07-20-2017, 03:47 PM
  2. S8 cant find Yamaha receivers bluetooth cant connect
    Last Post: 07-17-2017, 12:39 PM
  3. Just got the Pixel and I have two questions
    By dlalonde in forum Google Pixel & Pixel XL
    Last Post: 07-07-2017, 10:55 AM
  4. Is my Galaxy Note 4 capable of shooting raw images?
    Last Post: 07-06-2017, 03:51 PM
  5. S Pen Does Not Work With My Tablet Anymore
    Last Post: 07-06-2017, 09:08 AM
