Jessie Salinas
I've bought my Samsung Galaxy S8 when it was released and it came with a pare of AKG headphones. After some time, I realised that the right earphone is much lower than the left one.
Hey I had the same issue after one of mine for water on them. For all of you reading this pour running alcohol on the weak one for a few seconds, rinse it out, then dry them off by shaking them and using crops. Right after I did that they began working again. Worked for me, hope this was helpful ������
Yeah mate look at my lower reply
Use rubbing alcohol to rinse them
