How to stop popup ads on Samsung s8 edge
karl512
My mother-in-law just recently upgraded to a Samsung S8 Edge. She keeps getting popup ads randomly when unlocking the phone. They cover anything on the screen, even recent apps. You can also close the ad with a little x at the top right. Is there any way to get rid of these?
anon(238680)
4,839
13
Welcome as a new member. There is no S8 Edge, + maybe? But, same thing. Ads like that are caused by an app or apps that were installed. You can sometimes tell by the ads which app is causing them, then remove that app. As the phone is not very old, it might be a good idea, if she hasn't used it much, to do factory reset which should remove those.
msp1518
286
I was getting pop up ads and they were driving me crazy. I had no idea how they were happening but eventually figured out it was an app. Battery Life. I removed it and problem solved.
FEDUPWITHSAMSUNG
New Member but first have to say to MSP1518 why are you commenting on this Samsung S8+ thread when you are an IPhone user? Your fix is not going to be the same as an Andriod.
I am now getting these pop up ads and they are happening when my screen is locked. I hear low voices thinking I am going mad and turns out to be an ad running on my phone while it is in my pocket.
This did not start happening until the last Software update came through last week. I honestly don't think it is an app since I have not added any new apps and went in to every one on my phone and disabled all the notifications and other things. @PJRed2008 do you have any idea what else can be causing this? I am about ready to go to Verizon and return this phone since I haven't even had it for 30 days yet and it's driving me crazy. The last thing I need is one of these ads to start running in my pocket while I am sitting in a meeting with a customer.
They are more than occasional too, happens at least a dozen times a day.
BratPAQ
137
While the app is running on the screen, press the recent button. It will then show you the list of apps running. And the one in front is the current running apps. And probably the apps that showing you the ads.
virxbmc
Active member
Jul 31, 2017
42
Might not work, since the OP said they cover everything, even recent apps.
bobbob1016
114
These are not necessarily seen as the same as those notifications. I insta-one-star any crApp that spams my notifications but have yet to see pop-up ads. There is a setting in Bixby about Promotions. Have you installed any "questionable" apps? Anything that promises free wallpaper? Free youtube downloading? Anything like that? It could've been an update to one of those apps too.
Check the Bixby settings for promotions, but beyond that, try uninstalling apps.
Are we allowed to suggest programs that block certain DNS queries that would cause these popups? (Trying to be vague just in case)
Gary02468
2,145
9
38
What else could cause these ads if not one of your apps? It's certainly not normal behavior for an S8/S8+.
If you boot into Safe Mode for a while (which temporarily disables all your add-on apps), you'll see that the pop-ups stop.
Doug Moffat
765
Even familiar apps modify their advertising over time. Just because it's an old app doesn't guarantee against offensive ads.
anon(5719825)
Retired Moderator
Feb 21, 2013
3,797
I suggest installing Adguard as mentioned above. Guaranteed it will prevent any app from doing what your free app is doing.
I have not had an app do this to me in about two years now.
kimoloka
I haven't found any Adguard app that costs $10. Also, the app claims to only stop ads from popping up in a browser window, not push notifications from other installed apps
anon(5719825)
Retired Moderator
Feb 21, 2013
3,797
The Adguard app gives you a 7 day trial for free. After that you can pay for a lifetime license or yearly.
It blocks ads in apps through the use of a VPN. It sounds like you don't have the correct app installed.
Nanran21
