1. AC Question's Avatar
    So over the last few days I have been having a weird problem with my phone. It keeps spamming a message with "No usb connected/disconnected" and it's starting to get really annoying. It keeps my phone screen turned on at all times because of the message popping up. I have been googling around but can't seem to find a solution for it. I have recorded a video of it on screen that hopefully can show you guys what I'm talking about.
    Any help is highly appreciated as this issue is starting to get really annoying and draining my battery as well as it keeps turning my screen on and off all the time.
    07-12-2017 04:09 AM
  2. alinixa's Avatar
    07-12-2017 04:10 AM
  3. DJ Mac's Avatar
    I had the same problem. It started shortly after I put one of those magnetic mounts on the back of the cover that stick to a metallic ball that you stick to the dash of your car. I took the magnetic bit off the cover and after a while it stopped doing the usb connected / usb disconnected thing (which was a real pain because it kept turning the screen on constantly).
    Whilst it did do it for a few minutes a couple of days later, I gave the USB port a bit of a cleanout using some paper folded over and scraped out a bit of "dirt" and it has been ok since. This is NOT a software issue as the first thing I did after TWO DAYS of the phone having the problem was a FACTORY RESET and that did NOT fix it, hence I new it was a physical / hardware issue.
    Regards,
    Dean - Central Coast, Australia
    08-05-2017 10:51 PM
  1. Samsung Galaxy A3 2017 won't charge
    By rspau26 in forum Samsung Galaxy A3
    Last Post: 08-21-2017, 08:14 AM
  2. Unable to maintain a Wi-Fi connection
    Last Post: 07-14-2017, 12:46 AM
  3. Skype on S7
    Last Post: 07-12-2017, 04:11 AM
  4. Samsung knox consuming a hell lot of space
    Last Post: 07-12-2017, 03:19 AM
