1. Danazman's Avatar
    I have a few sites that don't have apps and have to use their website... so I created shortcuts to my home screen.... however.... when I try to add the shortcuts to my edge panel folders, it doesn't show up to select from the list when you try and add it to the panels....
    Any work around for this? I have all my apps in folders on my edge panel to keep from cluttering up my home screen.
    Thanks
    07-15-2017 09:40 AM
  2. alwilliam's Avatar
    You can download Bookmarks Edge panel designed to bookmark websites. Its free.
    On the other hand if you make a folder of those shortcuts, it's just a swipe up from your home screen. Folders usually appear first in your app drawer. So instead of swiping from the edge for the edge panel/s, just swipe up to reveal the app drawer.
    I do the same. I have no apps in my home screens. Just a clean look with a small clock and weather widget and a transparent calendar on the second one.
    PJRed2008 likes this.
    07-15-2017 10:51 AM
  3. paridge's Avatar
    The bookmarks edge is a good place to start. If you have too many bookmarks for that panel, there's a workaround using the tasks panel. You can put the bookmarks on a home screen. They can be in a folder. Then add them to the tasks panel. It's a duplication, but it allows you to access them from the edge panel.
    07-15-2017 12:13 PM
  4. bassplayrguy's Avatar
    Could post a Hoeven pic? I am seriously considering doing this as well.
    07-17-2017 04:47 AM
  5. Dconn1975's Avatar
    Same here. That's interesting.
    07-17-2017 05:53 AM
  6. alwilliam's Avatar
    Wait, what exactly do you want me to post? What is "Hoeven"?
    07-17-2017 11:14 PM
  1. How to change vibration intensity in Samsung Galaxy J5 Prime?
    By Mercerex in forum Samsung Galaxy J Series
    Last Post: 09-26-2017, 06:09 PM
  2. Replies: 1
    Last Post: 07-17-2017, 01:03 PM
  3. Replies: 1
    Last Post: 07-17-2017, 01:02 PM
  4. Replies: 2
    Last Post: 07-16-2017, 08:33 AM
